*searched* changing struts on 1991 civic sedan
so my manual decided it only wants to cover 1984-1987 AWD models.. which is kind of weird and shitty at the same time.
Anyways, i did do a search on this. i know i had found info in the past, but i cant find it now. can anyone direct me to a resource that will assist me in changing the front struts on my 91 sedan? i got the passenger side one OUT, now i have a few questions...
so am i right that we dont need to compress the spring on the front? thats only in the back, correct? how do i change the fork, spring, etc over to the new strut? i used to know how to do this, but its taken me longer than i expected to get to it and now i cant remember and i cant find the write up.... someone help plz, i need to get the car out of the garage TONIGHT.
ohh, installing KYB GR-2s. thanks guys!
its a pretty straight forward job and if you have factory springs on still get you a spring compressor. i have a 89 sedan and i just put new kyb gr2s on. ive never done any shocks before and i did it no problem. it realy is a easy straight forward job.
front struts.
http://www.autozone.com/servle...5.jsp
rear struts
just diconect the lca, disconect the strut from lca, and then take out the bolts at the top of the struts in the trunk.
this is what i read before i went and did it.
https://honda-tech.com/zerothread?id=891136
hope this helps you out.
rear struts
ntegraGS-R
Jan 10, 2006 03:48 PM
