Ok, here's the deal on my H22. Update on "Fresh built H22" thread.
Old May 22, 2002 | 05:46 PM
Mikey3000's Avatar
Default Ok, here's the deal on my H22. Update on "Fresh built H22" thread.
the noise that i'm hearing is a whistling noise coming from the throttle body/intake manifold area. it's audible when i open the throttle while attempting to start the car. so it's not a mechanical problem....THANK GOD. so here's what the motor does. it catches (get's started) for about 1-2 seconds, then dies. this happens with no throttle. WITH throttle, it only lasts about .5-1 second. so, it's closer to starting (and staying on) w/o help from the throttle. anyone have any idea on this? i'm guessing the whistling and stalling go hand-in-hand.
thanks.
Old May 22, 2002 | 07:16 PM
aeolus's Avatar
Default Re: Ok, here's the deal on my H22. Update on "Fresh built H22" thread. (Boss Hogg)
is the idle screw opened up??
Old May 23, 2002 | 03:50 AM
Mikey3000's Avatar
Default Re: Ok, here's the deal on my H22. Update on "Fresh built H22" thread. (aeolus)
what do you mean by opened up? i can't tell if the idle screw is adjusted right since i can't get the car to stay on. if i have the wrong plug plugged into my MAP sensor, do you think that could cause the car to not stay on? you know, there's 3 identical harness plugs in that area: MAP, TPS, and EGR plugs all look the same.
Old May 23, 2002 | 07:50 AM
apexii's Avatar
Yes it would. I know without the map it will not run and did the same thing on my prelude.
Old May 23, 2002 | 11:41 AM
Mikey3000's Avatar
Default Re: Ok, here's the deal on my H22. Update on "Fresh built H22" thread. (apexii)
ok cool i'll look into that.
Old May 23, 2002 | 12:37 PM
Mikey3000's Avatar
ok i just tried every possible identical 3 plug connector and it does the same thing. what do you think about the assumption of it not getting enough fuel? i have a fuel pressure gauge on the filter and that shows a good reading, but i don't know if my injectors are working or not.
smkelly1
Oct 23, 2012 04:04 PM
92Lude94
Mar 31, 2010 03:51 PM
jpnucrx
Mar 11, 2007 09:21 AM
crazi_E
Oct 4, 2006 10:22 AM
hulk_22
Jul 12, 2006 11:48 PM
