Bought a used tach, now Idle rpm is too high.
Old Mar 10, 2007 | 05:09 AM
AccordEX1991's Avatar
Default Bought a used tach, now Idle rpm is too high.
Is there a calibration screw or adjustment on the tach to set the idle rpm.
Idle rpm used to be 750, now it's 1100 rpm.
Thanks.
Old Mar 10, 2007 | 07:05 AM
standbackimapro's Avatar
Default Re: Bought a used tach, now Idle rpm is too high. (AccordEX1991)
What Tach is it?
Old Mar 10, 2007 | 07:19 AM
The-Kid's Avatar
Tach=Tachometer. Reads RPM...
Are you sure the tach is not F-Up... IDK but is the reading in the back like loose? It actually reads it perfectly but the meter is off. IDK... Show us a pix =D
Old Mar 10, 2007 | 09:35 AM
I bought a used instrument panel and just pulled out the tach.
I looked at the original one I took out and it has a screw adjuster on top.
Maybe that was it. I'll take a pic later.
Old Mar 10, 2007 | 02:35 PM
philadd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AccordEX1991 &raquo;</TD></TR><TR><TD CLASS="quote">I bought a used instrument panel and just pulled out the tach.</TD></TR></TABLE>
Oh boy... you pulled the needle off, didn't you?
Old Mar 10, 2007 | 05:34 PM
Default Re: Bought a used tach, now Idle rpm is too high. (philadd)
No. I just pulled the whole tach assembly.
No need to pull the needle when pulling the whole assembly.
Old Mar 10, 2007 | 05:48 PM
philadd's Avatar
Okay, just making sure. A lot of people like to pull the needles off before they realize they don't have to. At least, that's their excuse.
So, just to clarify... Is it the actual idle rpm that is too high, or is it just that the tach reads too high?
Old Mar 10, 2007 | 05:51 PM
JDM_DC4_Fanatic's Avatar
you still havent answered what tach it is. Is it from an accord? Honda, toyota chevy? If its autometer, theres an adjustment in the back, and it can be calibrated. If its OEM Honda, the needle probably needs to be repositioned.
Old Mar 11, 2007 | 03:03 AM
Default Re: Bought a used tach, now Idle rpm is too high. (JDM_DC4_Fanatic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_DC4_Fanatic &raquo;</TD></TR><TR><TD CLASS="quote">you still havent answered what tach it is. Is it from an accord? Honda, toyota chevy? If its OEM Honda, the needle probably needs to be repositioned.</TD></TR></TABLE>
It's a used Honda Accord 1991 automatic instrument panel. I pulled the whole tach assembly and transfered it to the one in my car. My car is a 5=speed manual.
I saw a calibration screw that is covered with tape in the back of the tach. I will try that first and report back.
Old Mar 11, 2007 | 01:16 PM
Here is the screw I was talking about.
I will pull the dash instrument bezel and see if I can adjust the idle RPM.
Rotten Egg
Aug 24, 2009 10:20 PM
DejaVu88
Dec 13, 2007 08:20 PM
vinuneuro
Mar 28, 2005 11:41 PM
ramz7887
13
Oct 1, 2003 07:27 AM
