wide band loging through obdo ecu?
Old Mar 9, 2007 | 11:28 PM
jamesracer's Avatar
Default wide band loging through obdo ecu?
How do I log through the cn3 port? and using BRE software. How do I tie all of that together?
Old Mar 10, 2007 | 12:09 AM
redsolturbo's Avatar
Default Re: wide band loging through obdo ecu? (jamesracer)
http://www.pgmfi.org
look under the bre tab, you cut the secondary o2 sensor wire and run the wideband feed into that and calabriate it via bre, then disable secondary o2 sensor check when not running (mine is currently set to read from only 1 o2 , most using bre are set like this also) you need the datalogging software to and prefelbly and ostrich to make real time chip changes
Old Mar 10, 2007 | 02:20 PM
jamesracer's Avatar
Default Re: wide band loging through obdo ecu? (redsolturbo)
thank you. I am new at this ecu stuff. I have not done it yet. Just trying to get my ducks in a row first. I am close.
Old Mar 10, 2007 | 02:45 PM
shortyz21's Avatar
ive done it and it works great...
just read pgmfi
Old Mar 12, 2007 | 09:00 AM
nexgen91's Avatar
Default Re: wide band loging through obdo ecu? (shortyz21)
anyone have the link for this write up off pgmfi?? thanks
Old Mar 12, 2007 | 10:20 AM
nexgen91's Avatar
bump
Old Mar 13, 2007 | 08:09 PM
jamesracer's Avatar
Default Re: wide band loging through obdo ecu? (nexgen91)
i am new what does bump mean hear?
Old Mar 13, 2007 | 08:49 PM
Jarrat's Avatar
Bump means, everytime someone posts something new, the thread gets bumps back to the top of the list, thus showing you the newest, or recently replied threads at always at the top.
same as TTT (to the top)
Old Mar 14, 2007 | 10:15 AM
nexgen91's Avatar
Default Re: wide band loging through obdo ecu? (Jarrat)
like so: bump
aaronhume
Aug 3, 2006 12:18 AM
5lugSlug
Jun 20, 2006 10:19 AM
ATS*Mark
Feb 4, 2004 06:59 PM
Rywire
Jan 4, 2003 09:53 PM
