***How To Install New Radiator?***(help)
ok, so those of you that read my other thread on how to do a radiator flush, know that i had an overheat problem. Well unfortunatly the new rad cap didn't do ****...so i need a new radiator. (found the leak)
My question is, how easy is it to change a radiator? Anyone have a *how to* link? i'll really apreciate it.
hmm well i did it when i had my old buick and it was pretty much take the bad one out, drop the good one in. pretty basic and i even had parts left over
Jack up.
Drain the coolant via plug underneath radiator.
Unhook hoses.
Unhook fans from radiator (screws/undo clips).
Unhook 2 black radiator brackets (located on left/right side of the top of the rad).
Pull out radiator.
Thats it, I don't think I left out anything.
Unhook hoses.
Pull out radiator.
i'm assuming you have a G3 teg?
http://www.team-integra.net/se...D=763
there's instructions for a G2 there too. you may need to register to see it. it's very easy.
i bought any aliminum radiator, but i guess it's not a/c compatible. Here is the link http://www.houston-imports.com...28579
I tried intallin' it, but that sc condesner crap is in the way. All i need to know is if i need to or not. thanks.
*it's the leftover part after you take of the radiator*
