offset question
Why the staggered set-up? Anything over an 8" wide wheel is tough on a TL. I personally have 18x8 Volk gt-p with a 49 offset and I'm lowered with no problems at all. A 19x8 with a 53 offset is about the max for a TL. It all depends on how low you want to go...but a 9.5 wide is definetly out of the question.
Actually a 19x8 plus 53 would tuck way under the car fine. I run 19x8 plus 40 Privats on 225/35-19s lowered w/ Eibachs w/ no real issues. I just test fit a 20x7.5 plus 45 w/ 225/30-20s last weekend that actually fit even better.
On a TL and RL anything above 40 offset works great from 7.5-9". 9.5 plus 53 should actually work, close, but should work. It'll prob. sit right at the edge of the fender.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pistacio »</TD></TR><TR><TD CLASS="quote">^^^^I'm sure that didn't happen without some surgery to the fenderwells. Well, at least its proof it can be done, with a little modifying.</TD></TR></TABLE>
I"m sure with that drop and wheel selection he had to cut the inner lip out of the well completely.
i apologize for the thread jack...but...
considering you guys seem to know alot about what all this offset stuff means, i have a question.
Will the new TL rims fit in my 94 vigor (after doing a 5 lug conversion that of course)?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by j-spec_cc2 »</TD></TR><TR><TD CLASS="quote">Will the new TL rims fit in my 94 vigor (after doing a 5 lug conversion that of course)?</TD></TR></TABLE>
Should fit fine. What are you taking the 5 lug from?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95CDSedan »</TD></TR><TR><TD CLASS="quote">It should fit easily with rolling the fenders. I have a 95 Accord and I have 17X8" rears and I have a **** load of room to go wider on mine. Its all about offset.</TD></TR></TABLE>
94-97 Accords can take a lower offset than the 98-up Accords/TLs/RLs.
They have more clearance and less scrub issues whn it comes to wider wheels and lower offsets.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Autoworks »</TD></TR><TR><TD CLASS="quote">
Should fit fine. What are you taking the 5 lug from?</TD></TR></TABLE>
Well, considering that i believe the brake set up is the same from the 90-97 Accord, i am going to use the 5-lug swap guide that is in the Accord Forum........that is, unless you have a better idea or vehicle to use it from (no sarcasm intended).
Well, considering that i believe the brake set up is the same from the 90-97 Accord, i am going to use the 5-lug swap guide that is in the Accord Forum........that is, unless you have a better idea or vehicle to use it from (no sarcasm intended).</TD></TR></TABLE>
Acura Legend, I guess that's worth a shot. I hope it works well...throw some NSX calipers on it.
funny thing. i considered using the 5 lug set up from a legend, but was advised against it. i think it had something to do with the fact that the legend wasn't rotor over hub (or hub over rotor....which ever one is suposedly better). as for calipers, i plan on going with legend gs calipers for the front and most likely leave my rears alone. i'm unsure as to what rear calipers would be better. any suggestions?
i think i have more research to do as far as the 5 lug swap is concerned because to my knowledge, i haven't seen another Vigor with a 5 lug swap. if using the legend's 5 lug set up is possible, then i'll probably go that route considering it wouldn't be too difficult for me to find the legend parts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by from Accord FAQ Thread »</TD></TR><TR><TD CLASS="quote"> http://www.accordinglydone.com...=1292</TD></TR></TABLE>
mind you now, this is just by me assuming that the 4th and 5th gen accords use the same brake set up as the vigor, but i'm about 90% sure that they share the same suspension and brake set up.
classciv
Mar 19, 2004 08:32 AM
good to know!!
