installing 92-95 civic halo projecters???
hey all,
just got my halo projecters and didn't come with instruction. been doing some research but coulnd't find anything that will help me install it. does anyone know or know a site i can use to help guide me through this install? it comes with all the wiring but have no clue what there use for. thanks!
Who makes the projectors? Do they have a website? You could maybe try and iput the name and the model you have and search the internet for instructions if they have them. Might even luck out and find a pdf. file
Are they the one piece 3 bulb halo projectors? Think I got a similar pair in my civic. You should have a hot and a ground, one will run from the battery positive terminal, the other you can ground anywhere, it should also have a plug that will fit in to your wiring harness, then coming from each of the actual encasings will be a red and a black wire, where you wire those will depend on when you want the halos to be on. If you want them on as long as the car is on, you can simply run a wire from any switched 12v wire, or even from the fuse box under the dash, and ground them nearby. If you want them to be on only when the headlights are on, or only when the brights are on, you can again run a wire from the fuse box, or splice into the wiring for those lights and it will run off the same switch.
it is just the headlight with no corner light. that middle peice only. yeah it comes with the harness and stuff.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toolow69 »</TD></TR><TR><TD CLASS="quote">halo's suck</TD></TR></TABLE> expletive off! i dont need your fucken opinion *** hole!
i wouldnt put those on
i did that same mistake and bought more headlights after
save ur self the embarressment and humility of buying that ebay crap and send them back u suck at life like one once said and u could expletive off too cause ur probably a *** with ur single cam eg and vtec u cant feel
im planning on putting hid on the projecters. leave your opinion to your slef. singel cam but will kill your car anytime!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vt3c_eg »</TD></TR><TR><TD CLASS="quote">im planning on putting hid on the projecters. leave your opinion to your slef. singel cam but will kill your car anytime!</TD></TR></TABLE>
You're a very angry young man.
Someone doesn't like the same thing you do, you you feel the need to swear at them and say your car is faster?
You must be what, 16 years old?
I'm going to let you in on a secret:
Plug and Play HID kits have very poor light output, and large amounts of glare. Aftermarket projector headlamps also have very poor light output, and use halogen projector geometry, not HID projector geometry. Couple those together, and you will have massive amounts of glare, very poor cutoff, improper aiming, and not to mention you'll probably pick some color like 12K or 14K, thus putting out less lumins of light.
You're setting yourself for something that looks ugly, and will reduce the overall functionality of your car .... and will also **** off every oncoming driver within the continental United States.
okay. im not mad. not 16 too. i mean im here for help not for people bad opinions. okay i didnt know that. so you said that no matter if i put in hid my vision will still be blurring and people will hate me? i think im still going to give it a try. thanks!
I'll help you out if you help me with this:
https://honda-tech.com/zerothread?id=1918671
I'll save you the time for retrofitting and give you a good price
BTW pnp hid kit + ebay halogen projectors = no no
U'll end up selling the ignitor and bulbs, throwing away the halogen projectors and probably f'up your HID projectors if you don't know what you're doing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vt3c_eg »</TD></TR><TR><TD CLASS="quote">i think im still going to give it a try. thanks!</TD></TR></TABLE>
Your maturity and care for other drivers just astounds me.
hey im sorry. i want to see how it will look like. i mean if you can find me an example of how it will look like that will be great. until then im doing it.
are you talking about your projectors with a plug and play HID kit?
this is an example of an aftermarket projector headlight with HID's:
And this is an example of a tsx retrofit.
Check the cutoff line and blue colorband.
damn! are you for real! i mean it looks pretty blured up!. it is ugly! is there any way to bypass this ugliness!?
swapping HID projectors for those halogen projectors you got in your setup and then aiming the projectors before sealing the glass with the housing if you want HID's that is. If you just want the look of projectors then rotating the projectors and aiming them should do the trick right
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Striker_1818 »</TD></TR><TR><TD CLASS="quote">swapping HID projectors for those halogen projectors you got in your setup and then aiming the projectors before sealing the glass with the housing if you want HID's that is. If you just want the look of projectors then rotating the projectors and aiming them should do the trick right
this guy on honda-tech has tyc projecters and he use mcculloch 6000k and it looked nice. not all blurry.
here the site his username is :floored4door
</TD></TR></TABLE>this guy on honda-tech has tyc projecters and he use mcculloch 6000k and it looked nice. not all blurry.
that's bc tyc makes halogen and HID projectors...
and not all are aimed the same way thats why some get good aiming some others are garbage.
BTW, pnp kits = garbage
okay. so it depend on the maker of the projecters. can i still adjust the aim and still get a clear hid view. then what kit do you recommand for hid with projecters?
depends which would fit there
I wouldn't recommend any huge projector...
the e46 single xenon are just a direct fit but the output is not that great. If you want to use the tsx or s2000 projectors then you might just have to modify the headlights.
But if you wanna keep the projectors and they look ackward, you have to rotate the projectors so they'd look straight and well-aimed
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vt3c_eg »</TD></TR><TR><TD CLASS="quote">i see now!</TD></TR></TABLE>
That's doubtful. You seem like a total douchebucket. Maybe you should spend more time searching for "HID retrofit" threads than talking **** to your betters.
SPECIAL Headunit Wiring!! HELP Experts!!! Thieves CUT Original Wiring... So cannot use Wiring Harnes
sightless
14
Apr 27, 2004 04:43 PM
kay_animation
May 15, 2003 10:40 AM
