changed fuel injector seals...need guidance
Old Mar 9, 2007 | 06:06 AM
esty's Avatar
Default changed fuel injector seals...need guidance
89 accord lxi...i had to change the fuel injector seals and after doing so the car won't start...i can use starting fluid and she'll start then die...i believe the problem might air in the system but i don't know how to bleed it or re-pressurize it
tips, etc will be appreciated
Old Mar 9, 2007 | 01:20 PM
Perfectionist's Avatar
Default Re: changed fuel injector seals...need guidance (esty)
Make sure the injector clips are securely attatched and that you didn't break any of the wires. You can try to purge the air and pressurize the system by turning the ignition to "run" for a few seconds and back to off several times. I've had my rail open a few times and never experienced any starting trouble afterwards.
CHANCELLOR12
Mar 29, 2016 05:40 PM
mixmastermatt
Mar 8, 2007 06:44 PM
return_2020
Aug 30, 2005 06:08 PM
Turbo-Honda
Jun 30, 2004 09:39 PM
deepnite
Aug 9, 2002 10:52 AM
