Honda S2000 Honda S2000
s2k wouldn't steer today
Old Mar 9, 2007 | 04:19 AM
AP1 01's Avatar
Default PROBLEM - s2k wouldn't steer today
so im in NJ and it feels like 5 degrees right now and my hands are about to fall off..
anyway, i warmed the car up to 3 bars this morning, then proceed to back up.. when i was trying to steer the car to the left, it seemed like it was 'locked' .. so i moved forward again to my spot, then backed up again and tried to steer to the right.. STILL NO GOOD i would say the steering wheel rotates about 30 degrees on both directions, but then 'locks up'. and YES, i have the key in the steering column
my question is - has this ever happened to any of you? could this all be because of the freezing weather outside? she drove like a champ yesterday, but this morning, i had to take my CRV out to work
Old Mar 9, 2007 | 04:44 AM
Otherguy's Avatar
NASIOC.com
Default Re: PROBLEM - s2k wouldn't steer today (AP1 01)
something may of froze? ionno...
Old Mar 9, 2007 | 06:17 AM
LAS2K's Avatar
Default Re: PROBLEM - s2k wouldn't steer today (Otherguy)
power steering booster problem?
Old Mar 9, 2007 | 06:31 AM
dcturbols's Avatar
Default Re: PROBLEM - s2k wouldn't steer today (LAS2K)
Either the steering column lock is broken (unlikely)
Or you have a leak in the P/S system which is causing morning sickness.
Morning sickness refers to P/S fluid getting gummed up from cold weather and making it hard to move the steering wheel on cold starts, but you must have a leak for it to still be a problem after the car is warmed up.
Old Mar 9, 2007 | 06:54 AM
cmdr430's Avatar
Default Re: PROBLEM - s2k wouldn't steer today (dcturbols)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dcturbols &raquo;</TD></TR><TR><TD CLASS="quote">Or you have a leak in the P/S system which is causing morning sickness.
Morning sickness refers to P/S fluid getting gummed up from cold weather and making it hard to move the steering wheel on cold starts, but you must have a leak for it to still be a problem after the car is warmed up.</TD></TR></TABLE>
s2k has eps (electronic power steering)
Electrically Powered Steering System
In place of a conventional hydraulic system, with its hoses, fluid and power drain, the S2000 uses an electrically assisted power steering system. At low speeds, more power-steering assist is provided, which eases maneuvering and parking. As vehicle speed increases, less power assist is supplied, giving the steering a more direct feel.
http://www.hondanews.com/categ.../1501
Old Mar 9, 2007 | 07:20 AM
dcturbols's Avatar
Default Re: PROBLEM - s2k wouldn't steer today (cmdr430)
Right you are.... 10AM &gt; ME
Old Mar 9, 2007 | 07:21 AM
m R g S r's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cmdr430 &raquo;</TD></TR><TR><TD CLASS="quote">
http://www.hondanews.com/categ.../1501</TD></TR></TABLE>
yeah i was gunna say.....shouldn't have anything to do with the engine warming up or not. . . .
try checking the fluid leve...maybe it's low....maybe air in the system&gt;??
Old Mar 9, 2007 | 10:12 AM
Mr. Projekt's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AP1 01 &raquo;</TD></TR><TR><TD CLASS="quote">so im in NJ and it feels like 5 degrees right now and my hands are about to fall off..
my question is - has this ever happened to any of you? could this all be because of the freezing weather outside? she drove like a champ yesterday, but this morning, i had to take my CRV out to work</TD></TR></TABLE>
Never heard of anything like it.
If it was a fluid related problem though, why did the CR-V work just fine? Warming up the motor doesn't "heat" up the P/S fluid, it just moves it around.
What I'm guessing is that there's a bind in the joints on either side of the EPS rack, either due to the temperature or a physical obstruction.
Old Mar 9, 2007 | 10:17 AM
Francesco's Avatar
Francesco's Avatar
Where you at in NJ? Im south NJ.
Old Mar 9, 2007 | 07:01 PM
toofast4u752's Avatar
if it only rotates 30 degrees and then its completly locked nomatter how hard you turn. then its the steering column lock. bucause even if you have a malfunction in the power steering it would just make it hard to turn it would not lock it..
HeatherK1989x
Jan 10, 2018 07:21 AM
NOOdS
Feb 16, 2009 01:35 PM
Storm_Rider
May 23, 2008 06:56 PM
Ventolin
May 14, 2008 11:45 AM
96Civic_Coupe
Oct 16, 2005 01:09 PM
