Tial bov is fluttering like crazy!
Old Mar 8, 2007 | 08:49 PM
batboyvaj's Avatar
Default Tial bov is fluttering like crazy!
The bov was working fine a couple of days ago. I put on a KN filter onto my turbo and now its fluttering like crazy. The BOV has its own vac source straight into the Intake manifold. i have about 19 in of vac. I'm not sure what spring is in there. But I assume it should work fine cause it was working fine before? I tried taking the filter off also.
Old Mar 8, 2007 | 09:48 PM
stockb18c's Avatar
take it apart and put it back together might be seize up
Old Mar 9, 2007 | 09:35 AM
batboyvaj's Avatar
you were right...i just took it apart and it is seized. i will update you guys
Old Mar 9, 2007 | 09:39 AM
Schister66's Avatar
Man U FTW
this same thing happened before i got my tial 50mm....my bov was sticking and until i ran a filter i didn't notice it....once i had the filter on there, it started fluttering a lot more, but it was actually compressor surge
Old Mar 9, 2007 | 09:48 AM
SPOOLINmatt's Avatar
Default Re: (Schister66)
a lot of people get compressor surge and "bov fluttering" mixed up. COMPRESSOR SURGE can sound just like a fluttering blow off valve. Kinda confused me a couple of times.
Old Mar 9, 2007 | 10:10 AM
KeyserSoze's Avatar
Default Re: (SPOOLINmatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPOOLINmatt &raquo;</TD></TR><TR><TD CLASS="quote">a lot of people get compressor surge and "bov fluttering" mixed up. COMPRESSOR SURGE can sound just like a fluttering blow off valve. Kinda confused me a couple of times. </TD></TR></TABLE>
Does this fluttering you guys are talking about make noise or is it quiet and the bov is just opening and closing?? Just curious.
Old Mar 9, 2007 | 10:19 AM
Default Re: (KeyserSoze)
no its loud and it happens exactly when the BOV would make its sound.
Old Mar 9, 2007 | 10:20 AM
KeyserSoze's Avatar
Good info.
Old Mar 9, 2007 | 07:53 PM
batboyvaj's Avatar
all of a sudden my spring load is too heavy? I need to get a 9 lbs spring or something now. cause i can rev it up and get some boost and let go of the throttle and the bov will not open and cause the compressor to surge.
Old Mar 10, 2007 | 12:00 PM
dpetro1's Avatar
Default Re: (batboyvaj)
what spring are you using now? you said you have 19" at idle so the 9lbs spring should work fine, it might be a little light i guess. tial does recommend the 11lbs spring for 18-21"
Old Mar 10, 2007 | 02:45 PM
Hondatec38's Avatar
Default Re: (dpetro1)
^^^ I have also read that. I will be using an 11 psi spring. Your vac line inside diameter needs to be fairly large to provide ample vac to the valve.
Old Apr 5, 2007 | 11:51 AM
batboyvaj's Avatar
Default Re: (Hondatec38)
i have a 7lbs spring now and it still flutters at low boost. what diameter hose should i use?
Old Apr 5, 2007 | 12:32 PM
TiAL's Avatar
6mm ID minimum
get an exact reading of your idle vac at operating temp, only then can I tell you what spring you need
Old Apr 5, 2007 | 01:14 PM
batboyvaj's Avatar
i'm at about 18-19 in of vac at normal operating temp. i am using 1/4 hose directly to a 1/4 nipple off my victor x.
Old Apr 6, 2007 | 05:23 AM
TiAL's Avatar
between 18 and 21 is an 11psi spring
Old Apr 6, 2007 | 05:37 AM
jdmsiR20's Avatar
Default Re: (TiAL)
i'd like to use 1/4", but i guess the nipple on the bov isn't that thick
Old Apr 6, 2007 | 05:53 AM
TiAL's Avatar
Default Re: (jdmsiR20)
nipple on the BOV is .2845in (7.22mm)
Old Apr 6, 2007 | 08:33 AM
machine4321's Avatar
if any one wants to know what ompressor surge sounds like , listen to the WRC rally cars , they dont run BOV , ive always wanted that sound but then found out they dont use them lol
keep in mind they probly replace a turbo every few stages due to surg and the antilag systems
Snail EK
Jan 12, 2005 09:41 PM
igotyofire
Dec 30, 2003 09:54 PM
Typiko512
Oct 28, 2002 05:50 PM
utensil
Dec 26, 2001 01:39 AM
