Restrictive Flex Pipe (it has internally collapsed)
Old Mar 8, 2007 | 08:43 PM
Del Sol's Avatar
Default Restrictive Flex Pipe (it has internally collapsed)
As the title says, the inside of my flex pipe looks like it has partially collapsed. Here is a photo looking down into the flex pipe from the header flange:
I'm sure it wasn't that restrictive when I installed it! Is it a poorly constructed flex pipe or is something else wrong? I have the energy suspension motor mount inserts so there should definitely not be any excessive movement. Has anyone else had the same problem?
Old Mar 8, 2007 | 08:46 PM
k24em2's Avatar
Default Re: Restrictive Flex Pipe (Del Sol)
I've seen this before on quite a few cars with this style of flex pipe....The kind with the accordion thing inside seems to hold up better.
Old Nov 19, 2007 | 09:54 AM
Quade's Avatar
Default Re: Restrictive Flex Pipe (k24em2)
Did you change it? Is the car running better?
Old Nov 19, 2007 | 11:55 AM
k24em2's Avatar
Default Re: Restrictive Flex Pipe (Quade)
I would assume so, yes
stillsmokey
Dec 28, 2007 12:37 PM
AP Kreuzer
May 31, 2006 06:03 AM
r0yal
Welding / Fabrication
Apr 19, 2006 07:03 PM
