Armrest bracket
I just bought an armrest for my 98 hatchback because my hatchback doesn't have one. When I was installing the armrest, I noticed there are 4 screw holes (2 front, 2 rear). However, I was only able to locate the front two screw hole, since there isn't a rear bracket. Now I am wondering if the 96-00 armrest bracket is same as the 92-95 bracket.
To clarify, the bracket i'm referring to is at the rear of the armrest.
Thanks!!
Thanks!!
SLHondaParts.com will show you part numbers. HondaPartsDeals.com will show you part numbers too, and if you copy the location of the image (as shown above), they have the largest images I've seen posted online for the EPC.
http://www.slhondaparts.com/br...NSOLE
https://www.hondapartsdeals.co...+3740
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gato5254 »</TD></TR><TR><TD CLASS="quote">i put an arm rest in my hatch i just used longer bolts at the back worked </TD></TR></TABLE>
But what did it bolt to?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GloomyX »</TD></TR><TR><TD CLASS="quote">in the diagram... what does B-26 refer to?
Thanks</TD></TR></TABLE>
It's the bolts that hold the bracket down.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GloomyX »</TD></TR><TR><TD CLASS="quote">sorry, i should've been more specific with my question.
But I don't see that bolt listed in the parts list.</TD></TR></TABLE>
That's because it's on diagram B-26 (Parking Brake). You don't need those bolts because they're already on your car. If you needed those bolts, then you'd have a bigger problem than installing an armrest.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fatchance187 »</TD></TR><TR><TD CLASS="quote">B-26 is just the screw and mount that the back of the armrest bolts to.</TD></TR></TABLE>
No, B-26 is a part diagram.
The bolt itself is part # 93402-08020-08.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">
That's because it's on diagram B-26 (Parking Brake). You don't need those bolts because they're already on your car. If you needed those bolts, then you'd have a bigger problem than installing an armrest.</TD></TR></TABLE>
hmm... i'll double check on that..... *gulp*
hmm... i'll double check on that..... *gulp*</TD></TR></TABLE>
It's just the two bolts that hold down your parking brake bracket. If your parking brake works, then the bolts are there.
ok I gotcha I was trying to answer with the info provided
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">That's because it's on diagram B-26 (Parking Brake). You don't need those bolts because they're already on your car. If you needed those bolts, then you'd have a bigger problem than installing an armrest.</TD></TR></TABLE>
sorry it wasn't clear enough to me until you clarified with the additional diagram. good job on the follow up info, I didn't mean to try and give wrong info. just trying to help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fatchance187 »</TD></TR><TR><TD CLASS="quote"> ok I gotcha I was trying to answer with the info provided
sorry it wasn't clear enough to me until you clarified with the additional diagram. good job on the follow up info, I didn't mean to try and give wrong info. just trying to help</TD></TR></TABLE>
Not a problem at all. Most people that don't have access to a copy of the Honda EPC don't know what the diagrams are. If you look in the bottom right corner, you'll see the diagram # (5023-B260000 A)
Modified by Eran at 12:48 AM 3/9/2007
