Need help figuring out the correct compression ratio. was i sent the wrong ones???
Old Mar 8, 2007 | 05:37 PM
RS DC4 94's Avatar
Default Need help figuring out the correct compression ratio. was i sent the wrong ones???
I ordered 9:1 Wiseco pistons and a Cometic .030 headgasket for my stock gsr bored to 81.50. although whenever i punch all of the information in a compression caclulater (cspeed/zealautoworks) its saying it would be 8.3:1 CR. was i by chance sent the wrong pistons? the set i was sent has a dish of -12. how would such a low CR effect a Daily driven boosted car on say 15lbs? Thanks in Advance!
Old Mar 8, 2007 | 06:24 PM
JoePSI's Avatar
Default Re: Need help figuring out the correct compression ratio. was i sent the wrong ones??? (RS DC4 94)
Same issue came up with this guy. I really dont think these calculators are accurate or they are being entered properly, It also depends on how much machining is done to the block (decking, etc.). I know this doesnt help much but heres the other thread.
https://honda-tech.com/zerothread?id=1908167
Old Mar 8, 2007 | 06:54 PM
RS DC4 94's Avatar
Default Re: Need help figuring out the correct compression ratio. was i sent the wrong ones??? (JoePSI)
yeah, my motor is all stock besides being bored to 81.50mm.
Old Mar 9, 2007 | 03:07 AM
RS DC4 94's Avatar
bump
Old Mar 9, 2007 | 04:59 AM
JDogg's Avatar
-12cc in a gsr motor will be a hair under 9:1, so you're fine, dont worry about it
Old Mar 9, 2007 | 06:17 AM
KingOfQB's Avatar
Default Re: Need help figuring out the correct compression ratio. was i sent the wrong ones??? (JDogg)
wats the compresson height on the piston?
Old Mar 9, 2007 | 09:00 AM
RS DC4 94's Avatar
Default Re: Need help figuring out the correct compression ratio. was i sent the wrong ones??? (KingOfQB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KingOfQB &raquo;</TD></TR><TR><TD CLASS="quote">wats the compresson height on the piston?</TD></TR></TABLE>
not sure what you mean. dome is -12cc
boostfever
47
Oct 25, 2010 09:59 PM
eg:R
Oct 18, 2007 05:56 PM
ELPITUDO
Jun 26, 2007 06:19 AM
mikemskater
Apr 8, 2007 08:05 PM
RS DC4 94
Mar 3, 2007 06:07 AM
