gas cap / pressure releasing loudly when removing cap
So I went to fill up the tank the other day after inspection (the first tank of gas I've put in the hatch) and that bad boy hissed a lot when I took it off. It did pass the inspection pressure test though.
Anyone else have this happen? It's an 89 DX all stock w/ 182k on it. Just thought it was odd.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ninjarico »</TD></TR><TR><TD CLASS="quote"> It did pass the inspection pressure test though.
theres a reason why they pressure test it.. because its under pressure when your driving.
if the gas tank is under pressure then its going to hiss.. you dont have a problem.
theres a reason why they pressure test it.. because its under pressure when your driving.if the gas tank is under pressure then its going to hiss.. you dont have a problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by janz3n »</TD></TR><TR><TD CLASS="quote">
if the gas tank is under pressure then its going to hiss.. you dont have a problem. </TD></TR></TABLE>
That makes sense. Just weirded me out because I've never heard it that loud before. Thanks H-T!
theres a reason why they pressure test it.. because its under pressure when your driving.if the gas tank is under pressure then its going to hiss.. you dont have a problem. </TD></TR></TABLE>
turboef90
Apr 20, 2009 07:18 PM
igo4bmx
11
Apr 19, 2004 06:38 AM
