Foglight Install Problem
Old Mar 8, 2007 | 10:44 AM
dynamo's Avatar
Default Foglight Install Problem
I just installed a set of OEM foglights on my bumper. Everything fits and lines up well on the outside, however, the top of the driver side foglight is hitting the frame of the car right above it whenever there is a slightest vibration or even when the car is idling.
Has anyone ran into this problem before? And, aside from sticking a piece of foam or rubber between the foglight and the frame piece it's hitting, is there anything else that can be done to fix this?
TIA
Old Mar 8, 2007 | 10:49 AM
Eran's Avatar
HT White Ops
You can either put some butyl foam rubber .... or beat in the area on your car it's vibrating against with a BFH.
Old Mar 8, 2007 | 10:51 AM
oneSLOWEX's Avatar
BFH FTW!
Old Mar 8, 2007 | 11:02 AM
vtecftw's Avatar
i'm assuming that means big ******* hammer?
Old Mar 8, 2007 | 11:04 AM
dynamo's Avatar
Default Re: (vtecftw)
The area it's hitting against is not something I can grind off and I am not sure if it's something that can be hammered in enough to clear it. I'll look at it more closely tonight, but I don't think either is an option.
What's the rubber foam solution that is mentioned a couple posts up?
Old Mar 8, 2007 | 11:05 AM
envee's Avatar
lol yea. +1 for bfh. seems like a good solution to me.
Old Mar 8, 2007 | 11:07 AM
Eran's Avatar
HT White Ops
You can get butyl rubber foam from most professional car audio shops. They use it to pack between panels to prevent vibrations and rattles.
Old Mar 8, 2007 | 11:14 AM
dynamo's Avatar
Default Re: (Eran)
My concern is in how to attach something like that to the foglight, or having it rub against consistently since the foglight itself gets super hot when it's on. Thoughts?
Old Mar 8, 2007 | 11:16 AM
Eran's Avatar
HT White Ops
The body of the foglight doesn't get that hot. I'd attach it to the car instead of the foglight housing. You could use some wire and just wrap it around and twist it off.
Old Mar 8, 2007 | 11:18 AM
dynamo's Avatar
Default Re: (Eran)
Thanks. I'll try to see about the hammering approach first, but will go with the foam rubber if it's not feasible.
Old Mar 8, 2007 | 11:54 AM
iamthecolt45's Avatar
Default Re: (dynamo)
zip ties to attach it to the car
Old Mar 8, 2007 | 12:36 PM
dynamo's Avatar
Default Re: (iamthecolt45)
Well, I called pretty much every audio store in my area, and no one has Butyl Foam Roubber (not sure if it's an actual brand). I got something similar made by Cascade Audio, but it does look a little flimsy. The good part is that it's sticky on one side, so I can double them up and stick it to the frame location where it's rubbing. But yeah definitely going to see if I can do anything with the BFH first - I am sure that constally hitting even a soft surface is not good for the foglight, so it would be much better to eliminate contact alltogether.
Freshdot
Jul 17, 2009 12:01 PM
VietSpeed
Feb 13, 2009 06:36 PM
LBP
Mar 24, 2008 10:32 PM
EK45VTi
May 12, 2004 12:10 PM
lsvtec101
Mar 11, 2003 10:07 AM
