98 D16y8 Auto to 99 D16y8 5-Speed Swap Wire Harness Issues???!!
Old Mar 8, 2007 | 09:49 AM
MilanoRed_EJ8's Avatar
Default 98 D16y8 Auto to 99 D16y8 5-Speed Swap Wire Harness Issues???!!
My motor was an Auto D16y8 -- It was out of a 98 Civic EX.
I bought a 99 D16y8 Manual/5 Speed motor, complete with everything (ECU, Tranny, Dist, Intake Mani, etc) and half of the engine harness -- the harness is cut so i can't use it.
Anyway, would I be able to use my existing wiring harness that's the Auto 98 EX D16y8 harness and plug the harness into my 5 speed 99 engine, and plug the 99 ECU into the other side of the harness and not worry about a thing???
When I plugged up my auto harness, I got a set or a clip of wires that don't plug into the 99 5 speed ecu.
My question simply is can I use my Auto 98 Ex d16y8 engine wiring harness, with my 99 EX 5 speed ecu + motor without modifying anything in the engine bay???
I need help before I waste money!!!
Old Mar 8, 2007 | 09:52 AM
igo4bmx's Avatar
you need to repin two of the ECU pins for IACV
also the IACV plug for an auto differs from one for a manual.
wire in the new IACV plug to two wires, and then u move those wires on the auto ecu plugs to the right positoons.
u leave the fourth plug unplugged.
Old Mar 8, 2007 | 10:02 AM
Default Re: (igo4bmx)
Thanks, but do you have like a how to on that?
This is my first engine swap, and I've done basically everything myself, with the help of my uncle who knows basically alot for b and h series engines.
Any help is greatly appreciated!
Old Mar 8, 2007 | 10:10 AM
Luserkid's Avatar
Default Re: (MilanoRed_EJ8)
I think this thread helps some people do it, but i dont know, seems good to me maybe itll help you:
https://honda-tech.com/zerothread?id=1337459
Old Mar 8, 2007 | 10:24 AM
igo4bmx's Avatar
wait quick question
how are u able to connect an obd2a 98 wiring harness to an obd2b 99 ecu?
that should not be able to just plug right in....
here is a link to the pinouts and actual pics of the ecu ends...
http://hondaswap.com/swap-arti...47169/
Old Mar 8, 2007 | 10:29 AM
I plugged it up and it fit.
I will post pictures when I get home.
HotrodHooptie
Jan 6, 2018 02:59 AM
Josh1999Civic
Jun 27, 2016 03:42 PM
guessohw
11
Dec 25, 2012 01:59 PM
guedo148
Jun 14, 2007 11:12 AM
7PSI CRX
Sep 19, 2004 03:21 AM
