my lights
my headlights turn on and it looks fine but when i'm driving i can't see anything... ideas on why? also when i'm driving and the front of my car starts to bounce it makes a squeaking noise ideas on that?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yesSiReK »</TD></TR><TR><TD CLASS="quote">my headlights turn on and it looks fine but when i'm driving i can't see anything... ideas on why? also when i'm driving and the front of my car starts to bounce it makes a squeaking noise ideas on that?</TD></TR></TABLE>
Get some glasses.
Try adjusting them higher.
Get some glasses.
Try aiming your headlights downward some. You should be able to adjust them using a screw driver on the back of the front head lamps. One adjuster moves the bulb horizontally, the other vertically. Also, make sure your bulbs are in correctly.
As for the squeaking noise: Your car isnt really supposed to "bounce". If it feels bouncy then your struts may be starting to go out if not already. If its not bouncy, then it could be your bump stops or just some worn bushing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">Get some glasses.
Try adjusting them higher.</TD></TR></TABLE>
haha<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugen112 »</TD></TR><TR><TD CLASS="quote">Try aiming your headlights downward some. You should be able to adjust them using a screw driver on the back of the front head lamps. One adjuster moves the bulb horizontally, the other vertically. Also, make sure your bulbs are in correctly.
As for the squeaking noise: Your car isnt really supposed to "bounce". If it feels bouncy then your struts may be starting to go out if not already. If its not bouncy, then it could be your bump stops or just some worn bushing.</TD></TR></TABLE>
o i meant like when i go over bumpy roads and where are the bushings? wat do they look like 0_o... i'm new at these things
litterbox
10
Dec 23, 2004 04:48 AM
