HUGE SPIKING PROBLEM
I have a 95 Teg... a 50 trim, 50mm hks wastegate w/ a 11.7 lb spring 450 RC injectors, Walbro 255 lp fuel pump. and im running onlt 3in open down pipe...No boost controller and im spiking like 20lbs. and thats letting off early. once i see that that high i get scared but i dont know why. If any one can help that would be great.
if its an internal, im thinking its external, but if its internal there should be the wastegate and then the WGA arm. and there is like a screw that u can either loosen it or tighten it, this is what i used to turn the boost up on my srt-4 and wrx
