GSR not getting oil pressure
Old Mar 7, 2007 | 03:07 PM
boostedek9's Avatar
Default GSR not building oil pressure
Ok so today we went to fire my motor and we were getting nothing on the oil pressure gauge so we made sure the electrical connections were good, which they were...we pulled the valve cover and found not a drop of oil (yes there is oil in the engine)...The engine was just freshly built...I bought the oil pump in "brand new" condition off a member on here, I've already talked to him and he swears up and down that the pump is brand new from inlinefour and its never been used...Any ideas on what might be wrong?...I'm lost
Modified by boostedek9 at 8:31 PM 3/7/2007
Old Mar 7, 2007 | 03:24 PM
BoostedEG6's Avatar
Default Re: GSR not building oil pressure (boostedek9)
do you have a oil cooler or filter relocation?
Old Mar 7, 2007 | 04:16 PM
boostedek9's Avatar
No, no oil cooler or filter relocation.
Old Mar 7, 2007 | 04:19 PM
BoostedEG6's Avatar
Default Re: (boostedek9)
have you double checked the pickup and gasket at the pickup?
Old Mar 7, 2007 | 04:23 PM
PT66Y922Rx83's Avatar
did you prime the oil pump? If not, then it'll take some time for the oil to get into the all the passages. That's what a good assembly lube is for. Usually I spin the motor with the starter only hooked up (ECU unplugged, spark plugs out) until oil pressure comes up.
Old Mar 7, 2007 | 04:29 PM
boostedek9's Avatar
we primed the car w/o the distributor or anything plugged in...and got nothing, as for the pickup and the gasket we're pulling the pan tomorrow to check that!
Old Mar 7, 2007 | 05:11 PM
iBrandon's Avatar
How long did u let the motor run? before determining ur getting no oil pressure
Old Mar 7, 2007 | 05:12 PM
boostedek9's Avatar
We didn't let it run at all, we just primed it
Old Mar 7, 2007 | 05:15 PM
iBrandon's Avatar
try starting it for a few seconds see if it reads pressure... i did the same thing....prime the oil a few times..and no pressure in the gauge...but started it up, instant pressure...sometimes it takes a lil more then just priming..
Schister66's Avatar
Man U FTW
run it for a little longer before doing anything drastic....assembly lube will lubricate everything for a few minutes....you'll be fine
Old Mar 7, 2007 | 05:20 PM
boostedek9's Avatar
Question, will the car build oil pressure and send oil to the head and what not by just priming it or does the car actually have to run for a few seconds for this to occur?
Old Mar 7, 2007 | 05:24 PM
iBrandon's Avatar
if you properly lubed ur cams when u installed them, it will be ok for it to run for a moment...just close ur eyes and turn the key over! then open ur eyes and look at the gauge...BAM! pressure...haha just try it man..
Old Mar 7, 2007 | 05:25 PM
boostedek9's Avatar
alright we'll try it tomorrow and I'll get back to you guys
Old Mar 7, 2007 | 05:30 PM
y7turbo's Avatar
when i rebuilt my d16 it took about 45 seconds of cranking to even show on the gauge. after it started it shot up to 80psi.
good luck
Old Mar 8, 2007 | 08:32 PM
boostedek9's Avatar
runs :D thanks fellas!
Old Mar 8, 2007 | 08:44 PM
iBrandon's Avatar
Old Mar 9, 2007 | 05:44 AM
HiProfile's Avatar
Default Re: (y7turbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by y7turbo &raquo;</TD></TR><TR><TD CLASS="quote">when i rebuilt my d16 it took about 45 seconds of cranking to even show on the gauge. after it started it shot up to 80psi.
good luck</TD></TR></TABLE>
Same here. Took quite a while, but then again D16's hold quite a lot of oil in their crank girdle. BTW I suggest pouring at least half a quart of oil directly onto the cams. Filling it all at the hole only gets a small section. They don't need much oil though, as the motor cranks at ~60rpm to start, and the cams move half crank speed. They're also billet steel and work-hardened, so there won't be a big issue with wear.
Old Mar 9, 2007 | 06:06 PM
Dark19Acura's Avatar
Check your oil pan maybe is punched on the oil snifer!!
Old Mar 9, 2007 | 09:09 PM
y7turbo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dark19Acura &raquo;</TD></TR><TR><TD CLASS="quote">Check your oil pan maybe is punched on the oil snifer!!</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedek9 &raquo;</TD></TR><TR><TD CLASS="quote">runs :D thanks fellas!</TD></TR></TABLE>
b20eghatch
11
Jul 12, 2010 11:24 AM
EG6 Love
Feb 6, 2010 09:53 AM
idreamidrive
Oct 18, 2009 02:56 PM
lil'Joe1039
15
Mar 17, 2007 12:05 PM
G
Aug 19, 2001 06:02 PM
