GAS PEDAL PROBLEM
Old Mar 7, 2007 | 11:44 AM
christin's Avatar
Default GAS PEDAL PROBLEM
with in the last couple of month's my gas pedal is really stiff when you let off it is hard to kick it down: once it is down it works fine until i have to stop at a red light then in order to go when the light turns green is to press hard on the gas pedal and lunge forward any suggestions would be greatly appreciated....
I tried cleaning the throttle spring and i put WD-40 on the pedal but nothing has fixed it.....
thanks,
christy
Old Mar 7, 2007 | 12:40 PM
ifIexplode's Avatar
bump for this, my car does the same thing.
Old Mar 7, 2007 | 12:43 PM
philosofy1's Avatar
Default Re: (ifIexplode)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by christin &raquo;</TD></TR><TR><TD CLASS="quote">with in the last couple of month's my gas pedal is really stiff when you let off it is hard to kick it down: once it is down it works fine until i have to stop at a red light then in order to go when the light turns green is to press hard on the gas pedal and lunge forward any suggestions would be greatly appreciated....
thanks,
christy</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ifIexplode &raquo;</TD></TR><TR><TD CLASS="quote">bump for this, my car does the same thing. </TD></TR></TABLE>
don't use wd-40, it's not a lubricant. did you guys bother adjusting the cable? try that as well. not sure why this happens, it happens to me when i don't let my car warm up, which is somthing that need to be done anyway. do you guys let the car warm up first before driving?
Old Mar 7, 2007 | 12:48 PM
95ProjectEJ1's Avatar
Default Re: (philosofy1)
My car has the same problem... cold and hot. Im thinking its the throttle cable that needs adjusting. That should give a little play in the pedal before engaging right?
BLUIZE256's Avatar
if your not lettin the car warm up, that could very well cause that prob.
Old Mar 7, 2007 | 12:52 PM
ifIexplode's Avatar
Always let my car warm up. until the normal honda high idle at first goes down to normal. i actually just got my swap done, it hasnt been botherin me enough yet to mess with it. any other ideas? ill mess with it tonite.
Old Mar 7, 2007 | 01:38 PM
Relic1's Avatar
mine did the same thing when it had a small bend in it. replaced the throttle cable and the problem went away.
it could also be your throttle body is gunked up. Check that first.
Old Mar 7, 2007 | 01:40 PM
Syndacate's Avatar
If you're sure the cable is tight then lube up the connecting rotor a bit.
BubblegumTate's Avatar
Default Re: (Relic1)
Our 98 is like that. I keep meaning to get around to replacing the throttle cable, but I haven't yet. It's kind of embarrassing to drive like that.. it's like full throttle or nothing because of that place where it binds up and then finally lets go. :D
Old Mar 7, 2007 | 03:18 PM
BLUIZE256's Avatar
Default Re: (BubblegumTate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BubblegumTate &raquo;</TD></TR><TR><TD CLASS="quote"> It's kind of embarrassing to drive like that.. it's like full throttle or nothing because of that place where it binds up and then finally lets go. :D</TD></TR></TABLE>
didnt the 6th gens have some kind of recall cuz of that.. or is that somethin i just heard wrong?. .
Old Mar 7, 2007 | 03:50 PM
thesmogman's Avatar
Default Re: GAS PEDAL PROBLEM (christin)
This is normal. I have put up with so many in my shop it is almost unbelievable.
For all of you here is what I have done so you don't go down the same road.
New throttle cable
Adjusted with slack so the cable deflects 5mm. (By the book)
Removed the throttle body and throughly cleaned and sanded the carbon spots between the throttle plate and the body.
Also do not use any lubricant's on the actual throttle cable as it causes it to bind.
I have tried graphite, oil, grease, and others.
So my conclusion to this is that the throttle body has worn around the throttle shaft and a little air is seeping through where the shaft goes through the TB.
Thus the oil that I have applied gets sucked into the TB after about a week.
So when it starts to stick I add more oil and it works for two weeks and so on.
Hope this helps you all out.
Old Mar 8, 2007 | 05:59 AM
christin's Avatar
Default Re: (BLUIZE256)
i live in south Florida my car is always warmed up besides it does it all the time cold or hot it is the weirdest thing.
Old Mar 8, 2007 | 08:52 AM
EM1FORLIFE.'s Avatar
Default Re: (christin)
My 2000 Si does the same thing, cold or hot doesn't matter.
Old Mar 16, 2007 | 09:01 AM
christin's Avatar
Default Re: (EM1FORLIFE.)
i cleaned out my throttle body and problem is gone (but of course not before i went out and bought a new cable)
khronicboy420
Dec 24, 2008 10:18 PM
Nick M
14
Apr 22, 2006 08:26 AM
HXvtec
15
Mar 21, 2006 07:14 PM
jaycapz
16
Mar 10, 2005 06:05 AM
ludenutz
Jan 23, 2004 10:44 AM
