Wheel Bearing Replacement '02 Accord Coupe
Old Mar 7, 2007 | 11:35 AM
B18C_EJ8's Avatar
Default Wheel Bearing Replacement '02 Accord Coupe
Any idea if there's a DIY or How-To on replacing the front wheel bearings? I think I have one on its way out...
Old Mar 7, 2007 | 01:55 PM
Accord2k-Hybrid's Avatar
Default Re: Wheel Bearing Replacement '02 Accord Coupe (B18C_EJ8)
I've got one in my chiltons.
You're going to need a press to get those wheel bearings out.
I removed the whole piece that holds the wheel bearings and brought them to a NAPA, they usually have a machinest of some sort, he replaced the bearings quickly, I reinstalled everything and I was done.
Old Mar 25, 2007 | 01:53 PM
B18C_EJ8's Avatar
Is #2 in this diagram the wheel bearing??
Old Mar 25, 2007 | 06:57 PM
soon2bdropped's Avatar
Default Re: (B18C_EJ8)
no number 3...
Old Mar 25, 2007 | 07:14 PM
B18C_EJ8's Avatar
Really? The bearing is built into the hub assembly?
As stated in my cheap-*** Haynes manual, the bearing needs to be pressed out, but # 3 definitely doesn't look like it gets pressed anywhere since it's got screwholes...
Old Mar 25, 2007 | 08:08 PM
yes your right i double check and 2 is the bearing..
Old Mar 26, 2007 | 04:14 AM
TouringAccord's Avatar
H-T Order of Merit
https://honda-tech.com/zerothread?id=1928887
Old Mar 26, 2007 | 06:08 AM
B18C_EJ8's Avatar
Default Re: Wheel Bearing Replacement '02 Accord Coupe (TouringAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=1928887</TD></TR></TABLE>
OUTSTANDING!!
Old Apr 9, 2007 | 03:42 PM
B18C_EJ8's Avatar
I would imagine I should replace with Honda OEM parts, correct?
thunderboy
Mar 20, 2009 12:15 PM
z6hatchboy
Feb 6, 2009 06:31 PM
ViZ
Feb 11, 2005 07:52 PM
nwdrifter
Sep 28, 2004 12:15 PM
