Blowing smoke only when im boosting?
I'm blowing white smoke out my exhaust when I let off the gas pedal and then step on it again. I know the smoke is from me burning oil, but it only happens when im boosting. Whats going on?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cb7-R »</TD></TR><TR><TD CLASS="quote">blown turbo seals???</TD></TR></TABLE>
x2
x2
if your burning oil, i don't believe you will see some from your exhaust. you will smell burning oil if anything. its more than likely a seal. what is the condition of your head gasket.
well this happened to a friend of mine and he had to replace the turbo..i dont know if it would be the same in ur case..but when he hit boost it blew out a crap ton of white smoke out of the exhaust so he took it to a shop and they said his turbo was crapped out...u may wanna have a mechanic who knows about turbos look at it...GL
My friend installed a new turbo in the car right before i bought it. It was a new turbo from ebay
But it does not use that much oil. if i don't make it smoke a lot 1 quart lasts more than a month. I am in the middle of doing a compression check. i should have the time to do it tomorrow. could a fuel tip in, or some thing like that, create that much smoke? But i do smell the synthetic oil burning.
white smoke is antifreeze burning. You need to redo your head gasket....better do it now before the gasket fails completely and that crap gets into your oil and chews the crap out of your main bearings and turbo........
oranginal
Apr 28, 2012 05:35 PM
Redprelude98
Nov 25, 2008 10:42 AM
torqueless
Oct 29, 2005 02:59 PM
