NEED HELP ASAP!!!! on JDM d16
Old Mar 6, 2007 | 03:51 PM
Slammed Civic Si's Avatar
Default NEED HELP ASAP!!!! on JDM d16
okay so someone told me that there is a topic on here that gives a diagram on how to bypass the crank angle sensor by crossing two wires under the distributer. i have looked and looked but i cant find it. so if someone knows where it is if you could reply me the link that would be fantastic.
like stated in title this is on a JDM D16, and usdm 00 civic ex harness
Old Mar 7, 2007 | 02:00 PM
Darth_Accord90's Avatar
Default Re: NEED HELP ASAP!!!! on JDM d16 (Slammed Civic Si)
I know the 2 wirers you need to test it, but not sure if it's the same.
Pull the big 7 pin connector from dizzy, B and F are the 2 you need
to test the Ohms, but maybe crossing those 2 will cause a bypass.
The crankshaft angle sensor is bad in mine, and causes a crappy idle,
and when my RPMs get up, it acts like the car is being choked hard
until I back off the gas a bit. Good luck, and I would wait till you get
more input before trying my method, as I say, I'm not sure.
Slammed Civic Si
Mar 7, 2007 03:45 AM
R_type
Nov 27, 2006 11:36 AM
DTKim
Sep 9, 2004 05:13 AM
92LudeSI
Dec 10, 2003 03:23 PM
civic disobedience
Mar 28, 2003 06:51 AM
