reason for syncro sleeve going out?
Old Mar 6, 2007 | 02:22 PM
champLSinteg's Avatar
Default reason for syncro sleeve going out?
This will be the second time I open up the tranny because of a 3rd gear grind. The first time (around 4 months ago)the syncros were a little worn but the slider/sleeve was complete gone!...replaced it. Now second time around I check it out and the syncros look the same but the sleeve is almost as bad as last time . I am going to replace the whole 3rd/4th syncro set this time but I want to know what could cause it to go so quick? Its my daily driver so I rarely rev it high!
Old Mar 6, 2007 | 03:58 PM
Default Re: reason for syncro sleeve going out? (champLSinteg)
Hey Bense! any suggestions?
Old Mar 6, 2007 | 05:40 PM
Bense's Avatar
what kind of shifter are you using? Do hold the shifter excessively? How's your linkage?
hows your mounts?
Old Mar 6, 2007 | 05:57 PM
Default Re: (Bense)
stock shifter. I used to hold the shifter all the time but after the first time I really havent.
What in the linkage should I check?
Mounts look fine...maybe I should put some inserts and make it a little stiffer?
Old Mar 7, 2007 | 09:41 AM
ttt for some help!
Old Mar 7, 2007 | 12:26 PM
Bense's Avatar
best bet is to just take it apart and take pictures.
Did you inspect your shift fork?
Old Mar 7, 2007 | 01:03 PM
Default Re: (Bense)
I already to it apart. should I post up some pic of it?
Thanks
Old Mar 7, 2007 | 01:18 PM
Bense's Avatar
yes
Old Mar 7, 2007 | 01:26 PM
Default Re: (Bense)
alright. I'll do it when I get home tonight. One more thing...the mainshaft top bearing comes off very easily, I can pretty much take it off with my hand if I tried, it almost just slid off. It was like that the first time the sleeve got chewed up and I took it apart but I didnt replace it. would that have anything to do with it?
Old Mar 7, 2007 | 04:54 PM
Bense's Avatar
that's fairly normal IMO
SilasEk9
Jan 10, 2014 07:38 AM
swizz977
19
Jun 12, 2011 08:31 PM
turbo-crx
Transmission & Drivetrain
Aug 26, 2009 05:21 AM
msmotorsports
May 5, 2006 12:12 PM
B18c5__Owns
Apr 3, 2006 10:28 PM
