P75 or PR4 headgasket?????
Old Mar 6, 2007 | 10:07 AM
heretolearnandteach's Avatar
Default P75 or PR4 headgasket?????
Hi, I am going to order an OEM headgasket for my boosted setup and copper spray it. I am using a 1998 P75 LS head with a 1995 B18b1 block.
When I go on acuraautomotiveparts.org it says the headgasket for a 1995 is a PR4 and for 1998 is a P75. I always thought they were the same but dont want to order the wrong thing. They are also slightly different prices, the P75 being more expensive.
My question is, which OEM part number should I use?
P75- 12251-P75-004
or
PR4- 12251-PR4-004
Thanks
Old Mar 6, 2007 | 01:23 PM
Anyone????
Old Mar 6, 2007 | 02:00 PM
aboobybobpleez's Avatar
Default Re: (heretolearnandteach)
theyre the same..p75 is for newer ls and pr4 is for an a1, but same ****
Old Mar 6, 2007 | 02:26 PM
Hmmm so they are the same dimensionally then? I wonder why they have a diff part number and price then.
Does anyone know if there is a diff in material or something or if one is better then the other?
Old Mar 7, 2007 | 05:57 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by heretolearnandteach &raquo;</TD></TR><TR><TD CLASS="quote">Hmmm so they are the same dimensionally then? I wonder why they have a diff part number and price then.
Does anyone know if there is a diff in material or something or if one is better then the other?</TD></TR></TABLE>
Anyone???
Old Mar 7, 2007 | 06:27 AM
DaveF's Avatar
nothing differant about them.
Old Mar 7, 2007 | 06:31 AM
99B16Si's Avatar
i believe some of the oil galleries are different sizes but either will work fine. Id get the P75 tho
Old Mar 7, 2007 | 06:32 AM
SovXietday's Avatar
Anyone???</TD></TR></TABLE>
Nothing different. The Dseries blocks have the same thing, "different" headgasket between the Z6 and Y8 engines, but they're the same thing and will work for both engines.
Old Mar 7, 2007 | 07:36 AM
Thanks guys, Ill just go ahead and order the P75 one.
Also when copper spraying a head gasket, is there a certain method any of you guys like to follow. Do you do light coats and let dry for a certain amount of time or overnight?
Old Mar 7, 2007 | 08:12 AM
DaveF's Avatar
i like to spray 3-5 light coats, let it sit for maybe 15minutes before the next coat, and also like to let it "dry" overnight.. i dont put them on soakin wet ever.
Old Mar 7, 2007 | 08:17 AM
99B16Si's Avatar
i think thats a bit excessive, but whatever works
Old Mar 7, 2007 | 10:58 AM
Default Re: (dturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">i like to spray 3-5 light coats, let it sit for maybe 15minutes before the next coat, and also like to let it "dry" overnight.. i dont put them on soakin wet ever.</TD></TR></TABLE>
Great, thanks for the info. So 3-5 light dustings with 15 mins between each one and then an 8 hour overnight drying?
Do you usually hang them up from something to spray and dry? Or just lay it on the ground and flip it for each side?
Thanks again.
1990_integra_DA9
Aug 15, 2008 04:44 PM
integraboosted
Oct 3, 2007 10:12 AM
BeeEK9R
Jun 4, 2006 11:39 PM
TurboCoop
Mar 22, 2006 04:39 PM
the.hamburglar
Jan 25, 2006 08:51 AM
