water pump questions?
can i put an ls water pump from a 95 to a gsr block will it fit and mount correcttly? will my timing belt stay loose with a 19 tooth water pump idleaizer or no?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood »</TD></TR><TR><TD CLASS="quote">you can use it with the correct belt but it is not ideal or recommended</TD></TR></TABLE>
what? what ideal or not recomended?
the correct belt is the LS belt as the water pump has a different number of teeth on it as opposed to the GSR pump.
Just do it right the first time, a belt is what? 50 bucks?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALLMOTOR CRX »</TD></TR><TR><TD CLASS="quote">so if i change my gsr pump i have to change my timing belt as well what about the teeth on the vtec cams arent they diffrent as well? </TD></TR></TABLE>
ok, I'm make this simple
GSR timing belt needs GSR water pump
LS timing belt needs LS water pump
if you put LS water pump on GSR engine, use the LS timing belt.
Cam gears on b-series are all the same...Vtec has no difference on cam gears
Justintegra
Apr 20, 2008 12:46 PM
