Exhaust System Issue
Old Mar 5, 2007 | 12:12 PM
texas_tea_2k6's Avatar
Default Exhaust System Issue
I got a 95 integra... i got a 2.5" exhaust muffler and 2 1/2 inch pipes running, w/o a resonator. Before i changed the piping it sounded pretty, now let me remind you that the pipes were previously stock and the size was in the range of 1 inch. With that being told, now when i get on it i cant tell any kind of performance difference, my mid range is ok and the exhaust sounds high pitched now.
What i want to know if I get a resonator put on will the high pitch go away and do you think i should be able to tell a performance difference???
ANY IDEAS, LET ME KNOW THANX
Old Mar 5, 2007 | 03:01 PM
Mikey3000's Avatar
Default Re: Exhaust System Issue (texas_tea_2k6)
i would guess adding a resonator would reduce sound since that is what its designed to do.
Old Mar 5, 2007 | 09:35 PM
Default Re: Exhaust System Issue (Mikey3000)
I just had to double check, i didnt wanna feed any bad information.... One other thing i wanna know is it possible to get a HP gain add a resonator, or will there just a difference in the way the car drives???????
Old Mar 6, 2007 | 04:02 AM
Mikey3000's Avatar
it'll just make it feel smoother because of less sound. you won't gain any hp.
Old Mar 6, 2007 | 02:26 PM
Darth_Accord90's Avatar
If you get rid of too much back pressure, you'll loose bottom end torque.
You went from 1" pipes to 2.5" pipes, and without a resonator. You got rid
of a bunch of back pressure. If you add a resonator back in the mix, you
should notice some low end torque return, but won't add any HP.
Octanez
15
May 16, 2012 07:57 AM
HyperFlow
13
Oct 18, 2010 08:28 PM
petergriffen
Feb 7, 2006 03:07 PM
redteg1
Jan 24, 2002 04:48 PM
96tegsr
Oct 18, 2001 06:46 PM
