i need help
Old Mar 5, 2007 | 11:54 AM
LilBlaccHatch20's Avatar
Default i need help
i have a 92 dx hatchback, when i turn my car on it runs at normal temperature...within five minutes of driving it starts to get hot.if i park it goes back down to normal temp..what do you think could be wrong
Old Mar 5, 2007 | 12:06 PM
Burton7706's Avatar
Default Re: i need help (LilBlaccHatch20)
Have you checked your coolant level or thermostat.
Old Mar 5, 2007 | 08:15 PM
Default Re: i need help (Burton7706)
yea the funny part is its sucking the coolant but its not leaking or anything
Old Mar 6, 2007 | 02:10 PM
Darth_Accord90's Avatar
Check your head gasket, you could be sucking your coolant out through
there. Would also explain how fast your car gets hot as well!!
Old Mar 6, 2007 | 06:52 PM
Default Re: i need help (Darth_Accord90)
if that is the case will it harm my engine
Old Mar 7, 2007 | 01:48 PM
Not immedeately, but it's sucking out your coolant, and you're loosing
compression. Plus getting coolant into your engine, via your cyliders,
can cause internal rust, and start breaking down your oil. If what I said
happens to be the problem, I would get it fixed as soon as you can.
osn grind
17
Nov 4, 2011 12:22 AM
Uncle Ben's
Mar 25, 2010 10:27 AM
SOHC_MShue
Apr 16, 2005 02:42 PM
94gsr18kid
Dec 29, 2004 08:12 AM
Goldfingiz
Jul 25, 2003 06:20 PM
