throttle body coolant feed . pics please...
Old Mar 5, 2007 | 08:45 AM
D15Bbigred's Avatar
Default throttle body coolant feed . pics please...
I'm running a water cooled turbo for my up and coming project. and I'm trying to get a feel of what lines to tap and the way it looks. So any pics are very useful. lemmie see what you got. thnx
Old Mar 5, 2007 | 09:17 AM
D15Bbigred's Avatar
also what types of fittings people are using to tee it as well would be helpful. thnx
Old Mar 5, 2007 | 11:23 AM
mike1114's Avatar
Default Re: (D15Bbigred)
no pics here as I don't have a water cooled turbo, but IF I was gonn do it, I would tap the water neck that the upper rad hose attaches to with a fitting and run a coolant feed from there, and then I would tap the coolant drain bolt on the front of the motor with a fitting for a coolant return line.
Seems like the least amount of plumbing this way......
Old Mar 5, 2007 | 12:29 PM
D15Bbigred's Avatar
well i bought the tuner toys block adapter for the return. http://tunertoys.zoovy.com/product/WPAD
so i heard the best place for a feed is the throttle body. i'm not very good at tapping into my own engine. so i'm trying the easiest route. thnx for the idea. bump for some pics
Old Mar 5, 2007 | 12:52 PM
mike1114's Avatar
werd....basically that is what I said to do.
That fitting is a good idea.
Old Mar 5, 2007 | 04:06 PM
NJIN BUILDR's Avatar
Use the tb lines and eliminate the water path thru the tb.No need for a water heated tb.
Old Mar 5, 2007 | 04:26 PM
TunerToys's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D15Bbigred &raquo;</TD></TR><TR><TD CLASS="quote">well i bought the tuner toys block adapter for the return. http://tunertoys.zoovy.com/product/WPAD</TD></TR></TABLE>
Thanks BigRed!
An easy way to do this (if you don't need a place to put a temperature sender), is to just remove the line that feeds the throttle body. Then hook up one of each lines to the turbo to each of the connections where you took the TB line off. That way you are just puting the turbo in line with the rest of the system.
Craig
Old Mar 5, 2007 | 07:58 PM
D15Bbigred's Avatar
interesting. any pics to show what i'm doin. i have a grasp on it. and i know what i need to do. just wanna see what fittings people use and maybe a pic of someones actual setup
Old Mar 6, 2007 | 08:40 AM
D15Bbigred's Avatar
up
Old Mar 6, 2007 | 01:56 PM
D15Bbigred's Avatar
anyone...
Old Mar 7, 2007 | 06:05 AM
D15Bbigred's Avatar
pics??!!
Old Mar 8, 2007 | 06:08 AM
D15Bbigred's Avatar
last bump!
bigbadboy
Dec 1, 2006 02:32 PM
done
Oct 14, 2005 12:24 PM
Soccerking3000
Mar 1, 2004 08:28 AM
2000vsm
Aug 25, 2003 07:14 PM
Giuseppe
Jan 6, 2002 05:04 PM
