help routing water lines
Old Nov 29, 2006 | 08:52 PM
bigbadboy's Avatar
Default help routing water lines
where is the best place to put youo feed and return lines for a water cooled turbo?? pics would be greatly appreciated
Old Nov 30, 2006 | 05:17 AM
bigbadboy's Avatar
bump
Old Nov 30, 2006 | 06:21 AM
Topdawgg's Avatar
bump, also interested in knowing how people did it
Old Nov 30, 2006 | 06:25 AM
a1320addict's Avatar
Default Re: (Topdawgg)
Tap into the throttle body coolant line.
Old Nov 30, 2006 | 05:19 PM
bigbadboy's Avatar
anyone supply any pics. where is the best place to dump the return line at. also where is the best place to get a water line kit
Old Dec 1, 2006 | 06:36 AM
Topdawgg's Avatar
cmon, alot of people have a GT series turbo with coolant.... pics or diagrams would be awesome
Old Dec 1, 2006 | 08:46 AM
Here you go:
One line off the heater inlet hosebarb on the water oulet off the head.
One line off the barb on the throttle body.
Each line to an adapter, then to (in this case), stainless steel lines to the turbo.
All you're doing is incorporating the turbo into the coolin system, making a big "T", so to speak.
Hope that helps
Old Dec 1, 2006 | 08:52 AM
EJ1 wilcox's Avatar
On my d-series turbo I just tapped into the coolant line that goes from the head to the throttle body. There was a section of hardline, which I chopped in half and attached one end to one hose and the other end to another. Then I just ran the turbo inline... super easy.
It's really not that hard to do, just buy up some hose, find a coolant line, and hook them up. Only took me about 5 minutes total.
Old Dec 1, 2006 | 02:29 PM
ProjectBoosted's Avatar
Default Re: (EJ1 wilcox)
in theory shouldn't you be able to run the line from the block to the turbo and then from the turbo to the throttle body replacing the stock line altogether? or will that not work. i just bought a gt35r and will need to be doing this same thing real soon@
Old Dec 1, 2006 | 02:32 PM
EJ1 wilcox's Avatar
Default Re: (ProjectBoosted)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProjectBoosted &raquo;</TD></TR><TR><TD CLASS="quote">in theory shouldn't you be able to run the line from the block to the turbo and then from the turbo to the throttle body replacing the stock line altogether? or will that not work. i just bought a gt35r and will need to be doing this same thing real soon@</TD></TR></TABLE>
Yeah, that's basically what I did, but it was just easier to use part of the lines that were already there.
There are many other ways to run water lines, that's just how I did it.
h23vtec_dc2
Feb 28, 2010 04:47 PM
D15Bbigred
Mar 8, 2007 06:08 AM
Mr HYDE
Oct 2, 2006 06:07 AM
Accord94DX
Apr 27, 2003 12:31 PM
Giuseppe
Jan 6, 2002 05:04 PM
