92 si hb funky tach
Old May 22, 2002 | 06:01 AM
todds94teg's Avatar
Default 92 si hb funky tach
my 92 si tach some times starts to jump around, then the car starts to miss fire. the motor is always making a low pich rubing sound than gets louder when the tach goes nuts. any ideas or has this happend to any one else? I think that it maybe the distributor. but not sure i bought the car yesterday and drove it 200 miles home the problem started 134 miles into my trip so i'm new to this car. saving up for a swap and need the car for a few months. late
Old May 22, 2002 | 06:22 AM
95cx's Avatar
Default Re: 92 si hb funky tach (todds94teg)
Yeah this happened to my brothers 88 civic hatch that we bought for $100 it would do like the same thing that you are explaing, like the car would feel like its got massive torque cause its so jerky and you couldn't really rev it past 3k. So we picked up a used distributor for nothing and fixed the problem. SO yeah get urself a new one
Old May 24, 2002 | 01:16 PM
todds94teg's Avatar
Default Re: 92 si hb funky tach (95cx)
ok i replaced the distributer. the the tach is still jumping and the car is missing(alot when wot) any one have an idea what would make this happen? there is no engine code or check engine light. please help thanks
[Modified by todds94teg, 12:39 AM 5/25/2002]
Old May 24, 2002 | 04:19 PM
todds94teg's Avatar
what no one has any idea of what the problem is? ok i'll ask a ?
would or could a knock sensor retart timing and make the car miss fire and the tack to jump around?
what other sensors are working with timing the could cause this problem?
please help me
Old May 24, 2002 | 06:28 PM
HOOKUPS-PRO-CRX's Avatar
yes a knock sensor could however you would immediately get a check engine light #23 for the knock sensor. sounds like the ignitor or a bad ground to me. any local auto electric shop can diagnos this sort of problem for about 30-45$)
Old May 24, 2002 | 06:44 PM
todds94teg's Avatar
Default Re: 92 si hb funky tach (HOOKUPS-PRO-CRX)
thanks I'll try that
Old May 24, 2002 | 06:59 PM
no prob
Old May 24, 2002 | 09:02 PM
DaiJekBok's Avatar
My 97 GS-R did the exact same thing. Tachometer was jumping all over the place accompanied by a bad misfire (especially awful under boost). Turned out to be the ignitor.
Old May 25, 2002 | 07:58 AM
todds94teg's Avatar
Default Re: 92 si hb funky tach (DaiJekBok)
thanks ignitor is for sure next try. how mach are they ? any one have one for sale ?
Old May 25, 2002 | 08:07 AM
The_Head's Avatar
The same thing hapened to me and it turned out to be a bad ground to the ECU so have that checked out too, I thought it was the distributor too, since thats where the RPM signal is generated.
Old May 26, 2002 | 09:07 AM
todds94teg's Avatar
Default Re: 92 si hb funky tach (xThexHeadx)
where is the ecu grounded at
Old May 27, 2002 | 09:24 AM
check the ground on the thermostat it is a 10mm headed bolt that ground the main engine harness at the thermostat but i still say its the ignitor. ...............................................Imp ort B's....lol ha ha
Old May 27, 2002 | 10:22 AM
todds94teg's Avatar
the thermostat ground is good. looks like it's ignitor time. thanks
BeerMan
Mar 9, 2007 11:27 AM
XstouterX
Nov 1, 2005 02:33 PM
cyberjunkie
Aug 5, 2004 04:00 PM
raceboy71
Sep 3, 2002 02:33 PM
