Fuel Cut Strategy of the ECU - Any thoughts?
Old May 22, 2002 | 04:15 AM
EE_Chris's Avatar
Default Fuel Cut Strategy of the ECU - Any thoughts?
Awhile back (EnDyn Board), I was reading on how cutting fuel in a high-vacuum situation is not ideal (as the Honda ECU does do this when you let of the throttle and coast) for a turbo. Reason being, was that cutting fuel could lead to a lean situation and blow your engine. Timing being cut/pulled back, apparently, was the key to keep things in check in this area.
Is this a real issue that needs to be addressed for the people running the stock ECU and fuel mod devices?
[Modified by EE_Chris, 1:16 PM 5/22/2002]
Old May 22, 2002 | 04:56 AM
Rocket's Avatar
Default Re: Fuel Cut Strategy of the ECU - Any thoughts? (EE_Chris)
Good point. The pintle style (stock) injectors aren't that quick and can leak a bit during deceleration fuel cut-off.
Easy fix, get some RC (Lucas) disc type injectors. They have quicker response and won't leak.
I used to run my GSR with only the resonator and it would burble on deceleration with stock injetors but that stopped when I ran RC injectors.
Violentpanda
Sep 11, 2018 02:57 PM
rlembitz
Dec 24, 2010 09:04 AM
feriotypeR
Engine Management and Tuning
10
Dec 16, 2009 09:31 AM
tbisme
Jan 3, 2003 07:43 AM
Teluan
Aug 29, 2001 09:04 PM
