Old Mar 25, 2015, 10:55 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
Print Wikipost
How much $ for exhaust shop to install catback?
Old Mar 4, 2007 | 04:21 PM
JasonST's Avatar
Default How much $ for exhaust shop to install catback?
So I recently ordered an exhaust for my car, I tried today to install it myself, but I can't get the exhaust bolts off because they're too rusted on, and I can't get the car high enough off the ground for a breaker bar, and I don't have any air tools, so it's pretty much impossible for me to get it off, so I'm wondering how much would a decent exhaust shop charge to take the stock exhaust off and install the new catback?
Old Mar 4, 2007 | 04:24 PM
WalkerGSR1's Avatar
did you spray pb blaster on the bolts and let it sit? Muffler shop shouldnt charge more than 1-2 hrs labor.
Old Mar 4, 2007 | 04:25 PM
98GSRDC2's Avatar
Default Re: How much $ for exhaust shop to install catback? (JasonST)
the whole catback? probably like around 100 or less
Old Mar 4, 2007 | 05:11 PM
JasonST's Avatar
Default Re: How much $ for exhaust shop to install catback? (98GSRDC2)
Ok cool, it sucks cause I really wanna do it myself I just don't have the tools... I haven't tried pb blaster, does that work alot better than wd-40? cause wd-40 didn't do the trick, I finally was able to break 1 bolt loose but it was still so tight from being rusted that I couldn't unthread it without giving myself a hernia.
Old Mar 4, 2007 | 05:38 PM
tomithy's Avatar
PB blaster is supposed to work better than wd-40.
It's basically a 45 minute job, so a shop should at most charge an hour for labor.
Old Mar 4, 2007 | 05:52 PM
401tuner's Avatar
Default Re: (tomithy)
do you try appling heat to the bolts, im sure its hard to do without a lift and not a lot of tools but if you apply heat to the bolts and then get an impact gun and try and loosen the bolts right after you heat them there should be no problem getting them off. and oh yea pb blaster FTW!!
Old Mar 4, 2007 | 06:02 PM
sauceja's Avatar
Default Re: (401tuner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 401tuner &raquo;</TD></TR><TR><TD CLASS="quote">and oh yea pb blaster FTW!! </TD></TR></TABLE>
Old Mar 4, 2007 | 06:21 PM
deadline's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JasonST &raquo;</TD></TR><TR><TD CLASS="quote">So I recently ordered an exhaust for my car, I tried today to install it myself, but I can't get the exhaust bolts off because they're too rusted on, and I can't get the car high enough off the ground for a breaker bar, and I don't have any air tools, so it's pretty much impossible for me to get it off, so I'm wondering how much would a decent exhaust shop charge to take the stock exhaust off and install the new catback?</TD></TR></TABLE>
in cali it costs about 25 bucks
Old Mar 4, 2007 | 06:30 PM
dragonfly2k3's Avatar
Default Re: How much $ for exhaust shop to install catback? (deadline)
In PA it costs 200 for cat back piping, flex pipe, high flow cat, and labor. so id guess like 35-40 for the labor to put it on?
emooheo's Avatar
it cost me $60 before i knew anything about working on cars. Invest in air tools, impact wrench ftw!
Old Mar 4, 2007 | 06:39 PM
Blackturboteg's Avatar
Default Re: (emooheo)
Had the same problem living in RI everything is rusted. I still did mine though just throw it on jacks . Cut the bolts like any shop would and just replace them . Takes no time and just got to replace the bolts its alot cheaper than paying somone to do it.. That money easily saved doing it yourself
Old Mar 4, 2007 | 06:42 PM
RS'R''s Avatar
For the $50-100 you would spend at a shop, just get the right tools so you can do it the next time too... and REMEMBER to buy new bolts and apply threadlock
Old Mar 4, 2007 | 06:46 PM
Default Re: (RS'R')
Yep do it your self.... Tuning and maybe a seclet few other thing somone is doing for me besdies that im doing it all why pay somone 100 plus dollars to do a exhaust when u could do it for like 5 bucks if u got the tool if not like 55 and after that u can do the job all the time after that.
Old Mar 4, 2007 | 07:22 PM
JasonST's Avatar
Default Re: (Blackturboteg)
K I think I found a way around it. I'm ganna take the down pipe/cat off, then freaking take those bolts off any way i can, which will be much easier once it's off of the car, that way I don't have to pay a shop, but I'm thinking of getting a high flow cat since my stock cat is pretty old and small, but I'm kinda short on money, I was wondering if there's really much of a difference than a good cat, say the carsound cat, and a cheep ebay high flow cat.
Old Mar 4, 2007 | 07:38 PM
Default Re: (JasonST)
easiest way would be to cut them off and put new ones in . and ebay has test pipes and hi flow cats for cheap check
Old Mar 4, 2007 | 07:42 PM
JasonST's Avatar
Yeah i'm lookin Ebay does have cheep test pipes and cats but are they worth it? I'd love to get one cause I'm really on a tight budget here now. I just wanna know what the differences are between them and the spendy carsound and other spendy ones.
Old Mar 4, 2007 | 07:50 PM
RevanDA85's Avatar
The stock honda cats are great because they're already free flowing. but if you buy any kind i would recommend magnaflow hi flow.
Old Mar 4, 2007 | 08:21 PM
JasonST's Avatar
Default Re: (RevanDA85)
Yeh I'm just wondering what the differences are between the magnaflow and the ebay ones, cause they're both high flow, made from t-304 stainless steel, and 2.5", just wondering if anyone has any first had experiences with the ebay ones, are they any good?
Old Mar 4, 2007 | 08:34 PM
RevanDA85's Avatar
They definently won't clean as well. and that is the point of having one. Otherwise just fit a test pipe. I have magnaflow on mine just because the stock one cracked
Old Mar 4, 2007 | 08:47 PM
JasonST's Avatar
Ok, Guess i'll just stick with my stock one for now, its all rusted and stuff so I'm not sure how much hp is hoplding me back there, but when i get some money I'll get a magnaflow one.
Old Mar 4, 2007 | 10:15 PM
sik96teg's Avatar
Buy a drimel and some cutting wheels and go to work.
Old Mar 5, 2007 | 04:21 AM
Integra0057's Avatar
I got my skunk2 exhaust custom done at an exhaust shop with stainless steel piping and it was like 130.
Old Mar 5, 2007 | 11:37 AM
401tuner's Avatar
Default Re: (Integra0057)
do it yourself and save money, dont waste money on something like that man.
Old Mar 5, 2007 | 12:20 PM
redDAinteg's Avatar
wow, i feel like i got BIG TIME ripped off! I paid 350$$ for my catback exhaust which was 2.25" and a no name muffler and a 18" resonator. And this is with no cat.
This was like 3 years ago though.
redsled
Honda Civic (2006 - 2015)
Apr 27, 2009 09:38 AM
scubba
Honda S2000
22
Oct 26, 2007 11:17 AM
Luchini
Sep 12, 2004 08:28 PM
CRXstress
Jun 4, 2004 07:06 AM
io_burn
Mar 17, 2003 08:16 PM
