Unknown DTC
Old Mar 4, 2007 | 03:42 PM
JDMN's Avatar
Default Unknown DTC
I have a 1998 Honda Accord EX with a check engine light on. I scanned it with a Generic Scan Tool and found P1457 code.
Does anyone one know what that code is?? Please help!! Thanks
Old Mar 4, 2007 | 03:53 PM
BLKFLSH's Avatar
Default Re: Unknown DTC (JDMN)
P1457 = Evaporative Emission (EVAP) Control System Leakage (EVAP Canister System)
Old Mar 4, 2007 | 03:59 PM
BLKFLSH's Avatar
Default Re: Unknown DTC (BLKFLSH)
From what I've read so far, it could be the gas cap. Make sure it's on right. (It may take a few drives to clear the code if the cap was the problem). My tether cord got trapped under the cap once, and caused the CEL. Good luck.
Old Mar 4, 2007 | 06:39 PM
JimBlake's Avatar
I think the gas cap should cause P1456 (EVAP leak, gas tank system).
That code P1457 could be caused by a few bad solenoid valves, including the EVAP purge valve on the firewall. The other valves are back at the EVAP canister. The EVAP canister for 1998 is located about underneath the car, below the left-rear seat. The EVAP vent-shut valve is a common one.
First, you could look for leaking or disconnected vacuum hoses around the EVAP canister & at the EVAP purge valve.
If you want to do more troubleshooting, check this one & scroll down to my post.
https://honda-tech.com/zerothread?id=748876
Old Mar 4, 2007 | 07:27 PM
JDMN's Avatar
nice!!! thanks alot..ahaha...its my girl friends car..and she didnt tighten the gas cap all the way...go figure...seriously..it was the old lady..ahaha thanks again!!
brad8266
Jul 12, 2022 10:28 AM
paulatg
Honda Civic (2001 - 2005)
Jul 23, 2014 09:02 AM
integra_type-r
Nov 3, 2007 06:29 AM
Josh10e
Dec 13, 2004 06:59 AM
slowj
Jan 18, 2004 11:18 PM
