clutch problems - is it the slave clylinder?
Old May 22, 2002 | 03:16 AM
743power's Avatar
Default clutch problems - is it the slave clylinder?
The past week and a half I've been loosing pressure on my clutch pedal and on saturday all of the pressure finally went. I thought it was the master cylinder brecause It looked to be leaking, so I replaced it. When I took the old one off, I found that it's still perfectly fine. There's no leaks anywhere in the lines. Could this be the slave cylinder? The car is a 96 ls.
Old May 22, 2002 | 04:08 PM
743power's Avatar
Default Re: clutch problems - is it the slave clylinder? (743teg)
come on. . . .I know somebody out there has to know. . .
Old May 22, 2002 | 04:18 PM
976's Avatar
976
New User
Loose slave cylinder bleeder screw
Clutch not fully bled
No cap on bleeder screw
Slave cylinder going - $15 at nopionline.com
You're alright, check if slave is leaking, or the lines, make sure to bleed completely, and put cap on bleeder screw agian...
gooblinn258
Jan 18, 2014 05:02 PM
R81_DC2
Aug 14, 2009 08:54 PM
hYbRiD EeEkAy
Aug 7, 2008 11:27 AM
anewfoundkevin
Sep 2, 2004 04:56 PM
Pandahatch
12
Aug 24, 2004 07:48 AM
