Can you use Stock retainers and aftermarket springs
Old Mar 4, 2007 | 10:34 AM
b16a4's Avatar
Default Can you use Stock retainers and aftermarket springs
Is it dafe to use Stock retainers and aftermarket springs?
with aftermarket cams?
what can happen
Old Mar 4, 2007 | 02:08 PM
b16a4's Avatar
Default Re: Can you use Stock retainers and aftermarket springs (b16a4)
anyone know this?
Old Mar 7, 2007 | 08:17 PM
klungemonger's Avatar
I don't know if it's a reliability issue with the actual retainer, I think most people swap out to the titanium since they weigh half as much which is better when you're revving higher and lifting higher simultaneously.
Old Mar 8, 2007 | 07:06 AM
Padawan's Avatar
Darth ModerVader
Yes, you can, unless the manufacturer specifically states otherwise. In fact, by using the OEM retainers, you avoid some of the potential problems that titanium retainers can present, though you sacrifice the weight savings.
RICE POLICE SIP
Aug 25, 2008 05:54 AM
rorik
28
Dec 25, 2007 12:44 PM
champwhiteEG6
26
Sep 26, 2007 02:09 PM
CustomX113
Dec 21, 2006 12:29 PM
bigsubs
Oct 15, 2006 07:20 AM
