installing a cam gear and shaft
i know i take the cover off of the cam gear. do i take off the valve cover 2? i know i have to take off the timing belt and pulley. what else do i have to take off. once it is off i know theres like 14 bolts and i side the shaft and cam in and bolt it back up. what are the other parts i need to take off?
I strongly recommend that you purchase an inexpensive Chilton or Haynes manual that will walk you through the process. It will also help with any other future projects.
What you downloaded is the bootlegged Helm PDF, though it should still contain the information. The Chilton and Haynes are actual books available at most auto parts stores. The only reason I suggest a manual is because there are specific torque values and procedures that must be followed when doing a cam installation.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chadalac1712 »</TD></TR><TR><TD CLASS="quote">no its the accual Book.</TD></TR></TABLE>
So you registered with Helm for their online service information program? Or did you download a PDF of the scanned manual for free? If you did the latter, then you have the bootlegged PDF as I stated, not the actual book. The information is the same, but the format and accessibility leaves a lot to be desired, as you found out.
Please enlighten on me how you use the search feature on a pdf. As a pdf is simply a picture of a scanned page - unless you're using recognition software I see that kinda useless. The picture of a word in a .pdf format is a far cry from the text form in a document such as an HTML page or a PHP database like this forum.
