how do u install a AEM cam Gear
Old Mar 2, 2006 | 09:54 PM
carbonek9's Avatar
Default how do u install a AEM cam Gear
need help putting in a cam gear in does it have to be done a certain way?
Old Mar 2, 2006 | 11:13 PM
JDMorgan's Avatar
its a pain in the *** if you don't know what you are doing. goto your haynes manual and look up timing belt change. same as that except remove the cam gears, and install the new ones. make sure to torque the cam gear bolts down.
pretty much loosen the tensioner bolt, pull the valve cover, pull the tbelt off the cam gears, change the gears, and put the belt back on(make sure timing is correct with the crank pulley)
DMCCOY
12
Jan 9, 2009 08:39 PM
NoVtecLs
Oct 10, 2004 11:01 PM
acatak
Jan 12, 2003 05:30 PM
oryanh
Jul 6, 2002 01:52 PM
REDBARON
Feb 26, 2002 11:12 AM
