99 Gsr Swap into 94 Del Sol couple questions?
We have the entire totaled gsr but i know the gsr is obd2 and we want to run the car obd1
so i'll need
obd1 b series dissy (will all work or need gsr specific?)
obd1 b series ecu or chipped p28
what sensors on the motor have different plugs, i think its most because of the OBD difference. But i know that you can swap many from the stock d15 but all are okay or no? Like what about the VSS?
Also what mounts from the integra do i need for the swap into the sol?
thanks
so i'll need
thanks
I bought an obd2 gsr, changed the alternator to obd1 i think there differant and plugged it in with obd1 ecu. It worked.
hmm check out these threads, i just did the same swap.
https://honda-tech.com/zerothread?id=1912219
https://honda-tech.com/zerothread?id=1864019
Essenar83
Apr 4, 2007 09:06 AM
