turbo leaking oil, what do you think?
Old Mar 3, 2007 | 01:48 PM
buttsneeze's Avatar
Default turbo leaking oil, what do you think?
this is the clearest pic i could get.......so what do you guys suggest?
Modified by buttsneeze at 3:00 PM 3/3/2007
Modified by buttsneeze at 3:01 PM 3/3/2007
Modified by buttsneeze at 3:03 PM 3/3/2007
Old Mar 3, 2007 | 01:53 PM
Schister66's Avatar
Man U FTW
does it burn oil too? I'm guessing the seals are shot. What kind of turbo and how many miles??
Old Mar 3, 2007 | 02:05 PM
buttsneeze's Avatar
Default Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">does it burn oil too? I'm guessing the seals are shot. What kind of turbo and how many miles??</TD></TR></TABLE>
nope, i'm pretty sure i'm not burning any oil......the turbo is a turbonetics t3/to4b from a drag kit, only has about 2000 miles on it at the most (probably way less).
Old Mar 3, 2007 | 03:02 PM
coneheadsracing's Avatar
Default Re: (buttsneeze)
Mine used to do that after it would sit after driving it. It would burn off after a few minutes of driving. Running a restrictor at the turbo helped quite a bit for me. With a 3an line.
Most turbo's just use air differencial's too seal it up. On mine the only thing there is a snap ring which holds the shaft in.
Old Mar 3, 2007 | 03:43 PM
buttsneeze's Avatar
Default Re: (coneheadsracing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coneheadsracing &raquo;</TD></TR><TR><TD CLASS="quote">Mine used to do that after it would sit after driving it. It would burn off after a few minutes of driving. Running a restrictor at the turbo helped quite a bit for me. With a 3an line.
Most turbo's just use air differencial's too seal it up. On mine the only thing there is a snap ring which holds the shaft in. </TD></TR></TABLE>
Yeah, I only notice it after it's been sitting.......i guess it's not really leaking that much, but it's definitely leaking. my oil level looks good every single time i check it, but then again, i don't even drive the car that much.
by the way, where's a good site to order a restrictor with the line?
any other opinions would also be appreciated......
Modified by buttsneeze at 5:24 PM 3/3/2007
Old Mar 3, 2007 | 06:31 PM
shortyz21's Avatar
mine did that, then it stopped..
Old Mar 3, 2007 | 06:46 PM
B18C1CYA's Avatar
Default Re: turbo leaking oil, what do you think? (buttsneeze)
I would check the flange that is bolted to the oil drain on the turbo , I had the same problem and mine had a small crack in it , and mine also came with a drag kit , the flange looked like it was a cast peace not machined like the nicer ones ,
Old Mar 3, 2007 | 08:44 PM
buttsneeze's Avatar
Default Re: turbo leaking oil, what do you think? (B18C1CYA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1CYA &raquo;</TD></TR><TR><TD CLASS="quote">I would check the flange that is bolted to the oil drain on the turbo , I had the same problem and mine had a small crack in it , and mine also came with a drag kit , the flange looked like it was a cast peace not machined like the nicer ones ,</TD></TR></TABLE>
yeah, i can definitely check that.....especially since that's easy to get to! by the way b18c1cya, my manifold is on and i like it very much. i'll have to send you some pics or i'll probably just post one here......
Old Mar 3, 2007 | 09:17 PM
B18C1CYA's Avatar
thanks It took me almost 2 months to figure out where it was coming from , lol and then one day I tried to tighten it and it just let go in my hand no wrench or any thing just hand tight , haha
Old Mar 4, 2007 | 03:42 PM
buttsneeze's Avatar
here's a pic for ya b18c1cya:
by the way, still open for opinions if others want to chime in........
Old Mar 5, 2007 | 06:35 AM
buttsneeze's Avatar
i'm not sure if my line size is already 3an, but it came from the drag kit......
Old Mar 5, 2007 | 12:26 PM
buttsneeze's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by buttsneeze &raquo;</TD></TR><TR><TD CLASS="quote">by the way, still open for opinions if others want to chime in........
i'm not sure if my line size is already 3an, but it came from the drag kit......</TD></TR></TABLE>
does anybody know offhand what size comes in a drag kit?
Old Mar 5, 2007 | 12:27 PM
B18C1CYA's Avatar
yup -3 in the drag kit
Old Mar 5, 2007 | 12:35 PM
buttsneeze's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1CYA &raquo;</TD></TR><TR><TD CLASS="quote">yup -3 in the drag kit </TD></TR></TABLE>
then do i even need an oil restrictor? or is it one of them things that "it wouldn't hurt"......?
Old Mar 5, 2007 | 01:45 PM
BILLY_BLING's Avatar
the oil restrictor is a must for that small of a turbo
Old Mar 5, 2007 | 04:42 PM
TurbodTegSfaria's Avatar
the gasket for that flange was leaking on mine too,im trying to find the same gasket as a matter of fact because i just twisted my center piece of the turbo to have the oil feed straight up and down with the drain
Old Mar 5, 2007 | 05:32 PM
buttsneeze's Avatar
Default Re: turbo leaking oil, what do you think? (TurbodTegSfaria)
ok, here's a question.....
Since the oil restrictor will change the oil pressure that the turbo sees, will this change the way the turbo spools? Would it make such a difference that I would have to retune the car?
(sorry, just thought i'd ask out of pure curiousity)
Old Mar 5, 2007 | 05:46 PM
CustomX113's Avatar
Banned
Default Re: (shortyz21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shortyz21 &raquo;</TD></TR><TR><TD CLASS="quote">mine did that, then it stopped..
ditto, pretty wierd
Old Mar 5, 2007 | 06:23 PM
buttsneeze's Avatar
Default Re: (95dxb18c1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95dxb18c1 &raquo;</TD></TR><TR><TD CLASS="quote">
ditto, pretty wierd</TD></TR></TABLE>
ok, but you guys don't know why it stopped?
by the way, i've just spent half an hour searching wether or not i should use an oil restrictor, and now i'm confused more than before?!? some people say not, some people say to.
what about a -2an feed line instead of a restrictor?
Old Mar 8, 2007 | 01:51 PM
buttsneeze's Avatar
ttt
Old Mar 12, 2007 | 06:57 PM
i would def use a restrictor . hondas get alot of oil pressure,i just put a real small restrictor on mine,and it seems to be ok, i already driven the car aboput 30 miles
markaria
Jul 23, 2008 07:30 AM
South Bay Surfer
Jul 17, 2008 10:14 AM
blinger
Apr 18, 2007 06:57 AM
Novtecdohc
Jul 30, 2005 12:22 PM
Full-Race Henry
Oct 16, 2003 12:57 PM
