Couple Wiring Questions.
Alright. I have a 98 Ej6, swapped a 99 y8 into it.
Ran the car for a little while with the y7 ECU. Had finally bought a y8 ECU from a 96 Ex. I dont have the Vtec solenoid plugged in.
My question is after i swap ECU's/plug in the solenoid.
What else is left as far as wiring Vtec? Im sure its still a couple wires.
thanks.
thanks.
1 wire for vtec solenoid (from solenoid to ecu)
2 wires for vtec oil pressure sensor (1 to ecu, 1 to ground)
1 wire for knock sensor (from sensor to ecu)
Skeletor
Feb 23, 2003 05:15 PM
