how does a breather set up work
Old Mar 3, 2007 | 07:45 AM
raphael's Avatar
Default how does a breather set up work
like the title says. how does it work? what does it do?im kinda retarded
Old Mar 3, 2007 | 08:04 AM
Padawan's Avatar
Darth ModerVader
Default Re: how does a breather set up work (raphael)
What sort of breather? Are you referring to an oil catch can setup?
Old Mar 3, 2007 | 08:20 AM
Heylookits shawn's Avatar
Default Re: how does a breather set up work (Padawan)
what im going to be doing is T-ing the valve cover and pcv lines to one, then use an air compressor filter and then running it to my intake pipe. simple yet effective oil catch can, for under 30 bucks.
Old Mar 5, 2007 | 10:25 AM
raphael's Avatar
Default Re: how does a breather set up work (Heylookits shawn)
thats exactly what im talkin about how does this actually work?
Old Mar 5, 2007 | 10:44 AM
exactly the same way as the stock pcv system, youre just putting a filter in-line to prevent the oil from going into the engine.
Old Mar 5, 2007 | 10:54 AM
raphael's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Heylookits shawn &raquo;</TD></TR><TR><TD CLASS="quote">exactly the same way as the stock pcv system, youre just putting a filter in-line to prevent the oil from going into the engine.</TD></TR></TABLE>well wtf is the purpose then if the pcv valve is there?
Old Mar 5, 2007 | 10:58 AM
SkoundrelUSA's Avatar
cute little bastard
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raphael &raquo;</TD></TR><TR><TD CLASS="quote">well wtf is the purpose then if the pcv valve is there?</TD></TR></TABLE>
PCV valve only pulls the crankcase gases out, but doesn't filter oil thats in the vapor. The purpose of the PCV valve is its like a one way check valve.
People add catch cans so the oil from the vapors doesn't have to go back into the combustion chamber because oil lowers octane level.
I have mine setup as a open breather because I got rid of the whole PCV system all together. Here's the thread
https://honda-tech.com/zerothread?id=1199935
Old Mar 5, 2007 | 11:03 AM
raphael's Avatar
Default Re: how does a breather set up work (SkoundrelUSA)
thanx man all i needed to know
Veggie Man
Jan 19, 2013 06:32 PM
nuttybumpo
May 30, 2007 04:18 PM
HighRevn
Jan 21, 2007 03:39 PM
tzenisj
Jan 4, 2004 07:31 PM
ZUL8R
Nov 18, 2003 06:14 PM
