bad ecu
Old Mar 2, 2007 | 09:52 PM
eh2's Avatar
eh2
Default bad ecu
Does the check engine light stays on when the ecu is bad??
http://www.superhonda.com/foru...de+23
Old Mar 2, 2007 | 09:54 PM
nicko360's Avatar
* B A N N E D *
Default Re: bad ecu (eh2)
what codes are you getting?
Old Mar 2, 2007 | 10:14 PM
eh2's Avatar
eh2
Default Re: bad ecu (nicko360)
I have a 97 obd2 GSR motor in my 95 hatch; I ran the motor with JDM and USDM obd2 p72 ECU without getting any check engine light.
I want to use an USDM OBD1 p72 ECU for smog purpose, but I'm getting code 23 , the problems could be knock sensor/ECU/open wire circuit.
I have read on here from other posts saying, "Blah blah blach...most of the time the problem is the knock sensor". Common sense dictate that the USDM OBD1 p72 ECU is messed up. What is your opinion on my situation?
Old Mar 2, 2007 | 10:17 PM
nicko360's Avatar
* B A N N E D *
have you tried running another ECU? try that, and if you get no codes, you'll know what your problem is
Old Mar 3, 2007 | 07:09 AM
eh2's Avatar
eh2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nicko360 &raquo;</TD></TR><TR><TD CLASS="quote">have you tried running another ECU? try that, and if you get no codes, you'll know what your problem is</TD></TR></TABLE>
yeah, I have tried two other ecu with out getting a cel, but both are not obd1 p72 ecu.
https://honda-tech.com/zerothread?id=1853426
From this post I don't think my obd1 p72 ecu is tossed.
jonyi27
Jul 1, 2013 09:29 PM
Agent_EM1
11
Jan 27, 2009 02:24 PM
Jonovision
Aug 4, 2008 02:29 PM
eh2
12
Mar 3, 2007 08:16 AM
xpsonic
Jun 4, 2005 09:37 PM
