hid
Old Mar 2, 2007 | 08:09 PM
Jay-Spec02's Avatar
Default hid
I NEED help.... i bought a plug and play hid kit for my 2000 civic si... but i went to get it installed... and found out that there is no power going to the ballast... do i need something else for a plug and play kit? Or is it that its done...? and if so do i need a new one
Old Mar 2, 2007 | 08:36 PM
CeeJayy's Avatar
Default Re: hid (Jay-Spec02)
you should have retro fitted your lights instead....
Old Mar 3, 2007 | 04:07 PM
Jay-Spec02's Avatar
Default Re: hid (CeeJay16)
i bought ctr headlights and i want to put hids on becuz there not as bright
Old Mar 4, 2007 | 06:57 PM
Genuine Rolla's Avatar
Check all of the connections, make sure they are connected tightly and securely, then let us know if your ballasts arent getting any power.
Old Mar 5, 2007 | 05:08 PM
Jay-Spec02's Avatar
Default Re: (Genuine Rolla)
i had it checked... i was told theres no power coming from the ballast....also they sed the ballast was DONE.... shorted.. i dont kno if you can fix those....Can you?
Old Mar 5, 2007 | 05:23 PM
SOHC4life 96's Avatar
Default Re: (Jay-Spec02)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jay-Spec02 &raquo;</TD></TR><TR><TD CLASS="quote">i bought ctr headlights and i want to put hids on becuz there not as bright </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CeeJay16 &raquo;</TD></TR><TR><TD CLASS="quote">you should have retro fitted your lights instead....</TD></TR></TABLE>
He means put stock HIDs from another car into your headlights. It looks better and doesn't blind on coming drivers. HID kits = illegal.
Old Mar 8, 2007 | 08:15 PM
Jay-Spec02's Avatar
Default Re: (SOHC4life 96)
from wat i was told hid arent illegal if you get bright ones....
Old Mar 8, 2007 | 08:31 PM
Eran's Avatar
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jay-Spec02 &raquo;</TD></TR><TR><TD CLASS="quote">from wat i was told hid arent illegal if you get bright ones....
You seem to be quite misinformed.
Equipping a vehicle with aftermarket HIDs is illegal. No way around it. Even retrofitting "stock" HIDs from other vehicles into a non-HID equipped vehicle is illegal. You're not as likely to be hassled for having a retrofit, because you have a proper cut-off and aren't flare-blinding the entire road.
PnP HID kits are garbage, plain and simple. They have improper aiming, little to no cutoff, and the colors most people choose are not conducive to good visibility.
Invest in some decent H4 bulbs for your civic instead of a piece-of-trash HID kit. More light does not mean more visibility. Check the links in my sig to see a review of the Philips X-Treme Power H4 bulbs, and also the lighting FAQ to learn a little more on a subject you know very little about.
B18Sleeper
Lighting
22
May 7, 2008 11:49 AM
White V6
Apr 3, 2006 07:35 PM
Jimmii
Mar 14, 2006 04:36 PM
jdmjackol
Dec 29, 2005 10:50 AM
FritzInTN
Jan 26, 2003 05:50 PM
