Fumes in your car?
Old May 21, 2002 | 08:23 PM
eg_nezay's Avatar
Default Fumes in your car?
Somehow the fumes of my exhaust get in to my car, it gives me a headache sometimes .Does anybody have this problem? Ive checked and had it checked for any leaks but its all good. Do you guys think its cause of the test pipe? Whacha think?
TIA
Old May 21, 2002 | 09:03 PM
Damon B.'s Avatar
Default Re: Fumes in your car? (eg_nezay)
I have a testpipe and it does the same, but I don't see how the testpipe would have anything to do with it
Old May 21, 2002 | 09:07 PM
blackANESE's Avatar
Default Re: Fumes in your car? (CleanSi-T)
Its definately the test pipe.
Old May 21, 2002 | 09:18 PM
RR98DX's Avatar
instead of N2, CO2, and H20 with the cat, you are now pumping CO, VOC, O3, and NOx into the air because of the testpipe. that stuff smells ALLOT worse.
Old May 21, 2002 | 09:21 PM
Damon B.'s Avatar
Default Re: Fumes in your car? (RR98DX)
I'm sure it does, but how does it work it's way into the car? It should end up with the rest of the fumes out of the tailpipe right?
Old May 21, 2002 | 09:23 PM
RR98DX's Avatar
exhaust always gets into your car if you have the windows down. with no cat it just becomes more noticable (sp?).
Old May 21, 2002 | 09:26 PM
Damon B.'s Avatar
yeah, but I get that **** with my windows up....
Old May 21, 2002 | 09:37 PM
eg_nezay's Avatar
Yeah!me too!
Old May 22, 2002 | 04:44 AM
Mista Bone's Avatar
D Tranny Guru
check the area where the ebrake cable goes through the floor for leaks.
Old May 22, 2002 | 04:48 AM
spankaveli's Avatar
Default Re: Fumes in your car? (Mista Bone)
maybe you have an exhaust leak. check the gasket seals on the test pipe and/or o2 sensor
Old May 22, 2002 | 05:49 AM
KRiS1's Avatar
I had a similar problem not too long ago. I had a crack in the exhaust manifold.
Old May 22, 2002 | 05:51 AM
AutoXsi2000's Avatar
Would installing a Micron filter help? Has anyone done this to a 00' Si? Show pics if available...
Old May 22, 2002 | 09:44 AM
eg_nezay's Avatar
Default Re: Fumes in your car? (spankaveli)
<U>Ive checked and had it checked for any leaks but its all good</U>
eff that ish
Jan 29, 2005 01:29 PM
mkpl99
Apr 9, 2003 07:05 PM
Fatty_1775
Aug 5, 2002 07:48 PM
JDM_Type-R
Jan 2, 2002 04:07 PM
Edwin
Aug 9, 2001 05:47 AM
