1997 B20B 97 B20 motor with P75 head P75-1, what car is this from, compression ratio?
have B20B JDM motor
looking at the head stamp it reads "9/6" within the first circle, (also, the head is stamped with the lable " P75-1"; i think i have a 97 B20B motor....
1. does anyone know which car in Japan this motor came from (orthia, SMX, CRV, etc?) and what year?
2. anyone know what is the compression ratio on this motor with this P75-1 head?
3. what is the hp? torque? (i know this varies depending on what car it comes from) can someone help me understand
thanks in advance!!!
(engine supplier tells me this is high compression motor, but i think its low compression, very curious)
I've never heard of any LS or B20's from the factory having high compression. I think they're all under 10 to 1(somewhere between 9.2-9.4 to 1). I think the B20 with a P8R head is the best stock B20. Well atleast that's what I've been told since it has bigger valves.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92_VX_EG »</TD></TR><TR><TD CLASS="quote">I've never heard of any LS or B20's from the factory having high compression. I think they're all under 10 to 1(somewhere between 9.2-9.4 to 1). I think the B20 with a P8R head is the best stock B20. Well atleast that's what I've been told since it has bigger valves.</TD></TR></TABLE>
sorry, i need to clarify, i mean by low compression 8.8.1 and higher compression 9.4.1
so anyone know what compression i am running and what are my specs to my questions above?
thanks!
thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MKEK9 »</TD></TR><TR><TD CLASS="quote">have B20B JDM motor
(engine supplier tells me this is high compression motor, but i think its low compression, very curious)</TD></TR></TABLE>
anyone can help me?
thanks!
anyone can help me?
thanks!
if you have a pre-98 crv motor... i want to say you have an 8.8 comp ratio.
i bought my block from hmo...and it does not have a P8R head so it low comp ratio
Modified by JDMFreak at 9:38 PM 3/6/2007
JDM
96-98 Honda Orthia
143 HP, 132 ft/lbs TQ
9.2:1 compression
96-98 Honda Step Wagon
123 HP,133 ft/lbs TQ
9.2:1 compression
99-00 Honda Step Wagon
134 HP, 136 ft/lbs TQ
9.6:1 compression
96-98 Honda CRV (two variants)
128 HP, 136 ft/lbs TQ
8.8:1 compression
9.2:1 compression
99-00 Honda CRV
148 HP, 136 ft/lbs TQ
9.6:1 compression
96-98 Honda SM-X
128 HP, 135 ft/lbs TQ
8.8:1 compression
99-00 Honda SM-X
138 HP, 137 ft/lbs TQ
9.6:1 compression
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMFreak »</TD></TR><TR><TD CLASS="quote">if you have a pre-98 crv motor... i want to say you have an 8.8 comp ratio.
Modified by JDMFreak at 9:38 PM 3/6/2007</TD></TR></TABLE>
thanks, we have the same block then
I want to ask you:
1. what is the redline on this lower compression (8.8.1) B20 motor? how much can you rev to?
2. what do you think is the max HP and max Torque? and at what rpm?
3. is it wise to invest in a P8R block since it gives you more HP (20 more HP)?
4. do you have a FITV on your block/throttle body?
thanks!
I want to ask you:
thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CivicEH2 »</TD></TR><TR><TD CLASS="quote">
JDM
96-98 Honda Orthia
9.2:1 compression
9.2:1 compression
9.6:1 compression
8.8:1 compression
9.2:1 compression
99-00 Honda CRV
9.6:1 compression
96-98 Honda SM-X
8.8:1 compression
99-00 Honda SM-X
9.6:1 compression
does anyone know how I can tell if I have an Orthia B20 or CRV B20 motor?
what kind of head does an Orthia B20 have?
thanks!
JDM
96-98 Honda Orthia
9.2:1 compression
9.2:1 compression
9.6:1 compression
8.8:1 compression
9.2:1 compression
99-00 Honda CRV
9.6:1 compression
96-98 Honda SM-X
8.8:1 compression
99-00 Honda SM-X
9.6:1 compression
thanks!
well...the 96-98 Orithia came with a P8R head...the 96-98 Step Wagon also came with P8R head..the 96-98 CRV came with either P8R heads or P75...so its either a SM-X, CRV or 99-00 Step Wagon..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CivicEH2 »</TD></TR><TR><TD CLASS="quote">well...the 96-98 Orithia came with a P8R head...the 96-98 Step Wagon also came with P8R head..the 96-98 CRV came with either P8R heads or P75...so its either a SM-X, CRV or 99-00 Step Wagon..</TD></TR></TABLE>
thanks...you mentioned it might be Step Wagon
what head does a 96-98 Step Wagon have? what head for 99-00 Step Wagon?
you quoted the answer....only 3 models came with a P8R head and i gave you the 3 that came with P8R heads....check the quote you quoted..
you quoted the answer....only 3 models came with a P8R head and i gave you the 3 that came with P8R heads....check the quote you quoted..</TD></TR></TABLE>
thanks, does the 99-00 Step Wagon also have an P8R head since you mentioned the 96-98 Step Wagon has a P8R head?
(you mentioned the 99-00 Step Wagon has a P75 head, but its higher compression is suggesting to me it has a P8R head instead?)
thanks in advance!
thanks in advance!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CivicEH2 »</TD></TR><TR><TD CLASS="quote">http://www.nonvtec.com/forums/
i dont know why it matter since your head is a 97....</TD></TR></TABLE>
sorry and thanks, because right now this is the question bothering me a lot...
is there such thing as a p75 head, b20 motor that has high compression (9.6.1/9.2.1)?
...since the 99-00 step wagon <U>may</U> have a P75 head w/ 9.6.1 compression
