sohcCant rev past 4000
Old May 21, 2002 | 06:46 PM
CarbonEK96's Avatar
Default sohcCant rev past 4000
i got a little problem... i hooked up my msd box, coil, and cap about 2 weeks ago.... three days after i hooked it up it started hesitating after 5000-5500... now it got worse and it does it around 4000... it really dies out and takes for ever to rev out... got any ideas.... also to connect the box to the ignition.. i have to drill a small hole in the cap to run the wires
i have a 96 ex... d16y8 sohc
Old May 21, 2002 | 06:49 PM
Gump's Avatar
Default Re: sohcCant rev past 4000 (CarbonEK96)
your car is on safety mode, is your ECU throwing any codes?
Old May 21, 2002 | 06:57 PM
CarbonEK96's Avatar
Default Re: sohcCant rev past 4000 (Gump)
not sure... but why would it be on that? are you sure thats what it is... why it would be lacking power like that? the one guy at autozone that running a coil like that can burn up stock wires... would that have anything to do with it... or the hole i drilled letting in moisture?
Old May 21, 2002 | 07:00 PM
Gump's Avatar
well my friends Crx went on safety mode a couple days after we had changed his spark plug wires, cap, and rotor, his distributor had gone bad, yours might have done the same thing.
Old May 21, 2002 | 07:02 PM
CarbonEK96's Avatar
****... so how would i figure out the problem? check the ecu? how can i tell codes... im new at this one... just count how many times the led blinks and find the code?
Old May 21, 2002 | 07:11 PM
HybridPsi's Avatar
Your cat could also be clogged.
Marc
Gump's Avatar
if it's a second long blink thats a 10, if it's a fast blink then it's a 1, example is if you get 2 long blinks that equals to 20, and if you get 2 fast blinks that equals to a 2, understand? you can go here to look up ecu codes:
http://ff-squad.com/ecucodes.htm
[Modified by Gump, 8:12 PM 5/21/2002]
Old May 21, 2002 | 09:26 PM
blckcvc's Avatar
i have a heavily modified 99 ex with the d16y8. i have the msd ignition with the external coil and i have had no problems. seal the hole with silicone. i slit the rubber gasket and tucked the wire through and i have had no problems. make sure that you didnt mess up your timing when you had your dist cap off. it will run like **** if you timing is off. it is about 12-14 degrees advance depending on your setup. email me at sk82liv247@aol.com. i am curious to know what your other mods are. http://www.geocities.com/optimusracing p.s. if your check engine light came on, some automotive parts stores such as Autozone with check it for free. they have a tool that plugs right into a harness under your dash. it wouldnt hurt to pick up a repair manual when you are there. it was the best $15 i ever spent.
[Modified by blckcvc, 6:30 AM 5/22/2002]
Old May 22, 2002 | 08:04 AM
CarbonEK96's Avatar
Default Re: sohcCant rev past 4000 (blckcvc)
i guess should also tell you guys that i ran 2 bottles of n2o through the car... think that would cause it... but i set up everything correctly, i even had my timing back 6 degrees
95civickid
11
Jan 28, 2007 06:10 AM
Mr HYDE
Jan 7, 2006 01:33 PM
Hatch_Back_97
Aug 5, 2005 10:45 AM
SpoolnG2
Jun 26, 2004 03:55 AM
turboITR#704
Jun 6, 2003 11:17 AM
