shifting stiff
Old Mar 1, 2007 | 07:24 PM
94HONDAHEAD's Avatar
Default shifting stiff
ok I just toke out my engine and tranny together to change it out well when I put it back in and hooked everything up and tried changing gears while car is off it is really stiff i also changed clutch and flywheel well can anyone help me out thanks. my car is a 1994 Honda Civic Ex with a b16a
Old Mar 1, 2007 | 08:37 PM
2wheelhunter's Avatar
Default Re: shifting stiff (94HONDAHEAD)
stiff as in it wont go in gear? make sure everything is hooked up rite.. i bet its something minor u just over looked
Old Mar 1, 2007 | 09:20 PM
Chim Chim's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94HONDAHEAD &raquo;</TD></TR><TR><TD CLASS="quote">ok I just toke out my engine and tranny together to change it out well when I put it back in and hooked everything up and tried changing gears while car is off it is really stiff i also changed clutch and flywheel well can anyone help me out thanks. my car is a 1994 Honda Civic Ex with a b16a</TD></TR></TABLE>
You probably over-tightened the shift linkage. Try loosening the nut on the bottom of the shift lever a little bit. See if that improves things...
Old Mar 1, 2007 | 09:26 PM
ej63_civic's Avatar
Honestly man, its tough to say the b16 motor is pretty simple. I remember changing my clutch in my vw corrado and i had the same problem. I then looked it over and the shift linkage was way to stiff, like Chim Chim said just try loosening the shift linkage and see what happends. GOod luck though!!
Old Mar 3, 2007 | 11:47 AM
thanks a lot i will try that today
ramos2589
13
Jan 29, 2008 07:57 AM
94HONDAHEAD
Mar 1, 2007 07:13 PM
ZCRexSnglecamV
12
Jan 5, 2007 12:47 PM
MRturbo
Jul 7, 2006 08:14 AM
amh0001
May 29, 2005 08:28 PM
