shifting stiff
shifting stiff
ok I just toke out my engine and tranny together to change it out well when I put it back in and hooked everything up and tried changing gears while car is off it is really stiff i also changed clutch and flywheel well can anyone help me out thanks. my car is a 1994 Honda Civic Ex with a b16a
Re: shifting stiff (94HONDAHEAD)
stiff as in it wont go in gear? make sure everything is hooked up rite.. i bet its something minor u just over looked
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94HONDAHEAD »</TD></TR><TR><TD CLASS="quote">ok I just toke out my engine and tranny together to change it out well when I put it back in and hooked everything up and tried changing gears while car is off it is really stiff i also changed clutch and flywheel well can anyone help me out thanks. my car is a 1994 Honda Civic Ex with a b16a</TD></TR></TABLE>
You probably over-tightened the shift linkage. Try loosening the nut on the bottom of the shift lever a little bit. See if that improves things...
Honestly man, its tough to say the b16 motor is pretty simple. I remember changing my clutch in my vw corrado and i had the same problem. I then looked it over and the shift linkage was way to stiff, like Chim Chim said just try loosening the shift linkage and see what happends. GOod luck though!!
ZCRexSnglecamV
12
01-05-2007 12:47 PM
MRturbo
07-07-2006 08:14 AM
amh0001
05-29-2005 08:28 PM
