??? max spring lift vs. cam lobe???
if my my max spring lift is 12.5 mm will a cam w/ a 12.3 lobe work. i heard u needed extra incase of over revving.
thanks for ne help
thanks for ne help
As a rule of thumb you like to have .060" (1.5mm) more valve travel than lift.I assume you mean 12.3mm valve lift not lobe lift.
yeah sorry the lobe has a 12.3 mm lift and my springs have a max lift of 12.5mm. i had a set of crane cams radical street cams w/ these springs but my intake cam broke
96integra20
Mar 20, 2003 08:36 PM
